方案下载应用领域 | 航空航天 |
检测样本 | 航空 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司的双量程机载式相位多普勒粒子分析仪,在冰风洞中,对模拟的云层过冷液滴的粒径分布进行了测量,同时测量了液态水含量,并比较分析了与其它测量方法的差异。
Recently, FAA requirements for aircraft icing certification have been updated to include characterization of supercooled large drops (SLD). Cloud measurements and icing wind tunnel simulations of existing Federal Aviation Regulations, Appendix C, Part 25 and these new conditions (Appendix O) require advances in instrumentation capable of measuring droplet size and liquid water content (LWC) under a much wider range of conditions. Cloud microphysics investigations and measurements have revealed that some clouds containing large drops can have droplet size distributions that are bi-modal. Such conditions present an additional challenge to the instrumentation. Existing instrumentation based on concepts developed in the 1970’s are known to have difficulties measuring spray drops in the SLD range. Currently, up to five or six different instruments utilizing different measurement principles are needed to characterize icing clouds and icing cloud simulations in icing wind tunnels. The phase Doppler interferometer flight probe, dual range (PDI FPDR) has been developed to address these new and challenging spray measurement conditions. This instrument is capable of simultaneously measuring droplets in the size range of 1 μm to 2000 μm or larger and LWC over a full range of cloud and cloud simulation conditions. To ensure reliable operation under the harshest icing conditions, the probe incorporates deicing and temperature controls. Since the instrument is considered to be relatively new to the meteorological and icing research community, extensive tests and evaluations of the instrument were conducted to demonstrate its measurement capabilities. An extensive program of instrument comparisons between the well-established PMS FSSP and OAP instruments was conducted. Results of these comparisons are reviewed and discussed. Significant measurement differences were found under higher droplet number density spray conditions and these differences are discussed and reconciled. Comparisons of LWC measurements are also provided and compared to the well-established hot wire devices and icing blade data.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
