方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司的PDI-200MD型相位多普勒粒子干涉仪(PDI)对多横流角喷流羽流的液滴的粒径和速度进行了测量,并和CFD计算结果进行了对比分析。
The interaction of a spray plume within a confined crossflow environment occurs often in spray applications, most notably in gas conditioning applications. Characterization and modeling of the drop size and velocity distributions, as well as spray shape, was conducted within a controlled wind tunnel environment. The primary focus of this study is the effect of various incident angle cross-flows on the characteristics of a spray nozzle.
While the spray characteristics immediately downstream of the nozzle will govern the significance of the effect of the cross-flow, this study aims to provide a reference case
in order to guide and compare future work. A low flow rate, hydraulic, hollow cone spray was investigated with a nominally uniform cross-flow air speed of 15.4 m/s. These results demonstrate the trajectory change as well as the change in spray plume characteristics over a range of spray angles defined relative to a co-flow air stream.
The experimental results were acquired with an Artium Phase Doppler Interferometer (PDI). The computational model and simulations were conducted using the Ansys Fluent modeling software package in conjunction with methods developed at Spraying Systems Co. The computational model’s agreement, and disagreement, with the experimentally acquired results provides insight for the appropriate considerations when constructing crossflow
models.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
