方案下载应用领域 | 航空航天 |
检测样本 | 航空 |
检测项目 | |
参考标准 | 暂无 |
利用德国LaVision公司的由ImagerProX4M相机和DaVis8.2软件平台构成的层析PIV系统,对湍流的流场结构进行了实验研究。
This research dissertation focuses on the developments of tomographic PIV (tomo-PIV)
for the measurement of turbulent flows (Elsinga et al. 2006). It is based on the
tomographic reconstruction of a volumic intensity distribution of tracer particles from
projections recorded on cameras. The corresponding volumic distributions are correlated
to obtain 3D displacement fields. The present work surveys the state of advancement of
the research conducted on this technique and the main issues it has been confronted with
so far. The main research focus was on tomographic reconstruction. Indeed, its main
limitation is the appearance of ghost particles, ie reconstruction noise, which occurs
when high tracer concentrations are required for high spatial resolution measurements.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
