方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的Imager Intense型,ImagerProX型相机。PTU9型可编程时序控制器,和软件平台,分别搭建了2DPIV,2DPTV,3D层析PIV和3DPTV测量系统,并对湍流边界层的流场进行了测量分析。
Measurement of turbulent statistics in the inner layer of wall flows is of fundamental and applied importance for development of passive and active flow control systems A ccuracy of two and three dimensional particle image velocimetry ( and particle tracking velocimetry ( in resolving the near wall turbulen ce statistics of a channel flow is evaluated at Reynolds number of Re H 6700 (based on average velocity and channel height H equivalent to Re τ 190 (based on friction velocity u τ 0.0638 m/s and the half channel height, H 2). The channel has a rectangular cross section of W × H 40×6 mm 2 and wall unit of λ 16.2 μm. The evaluated 2D techniques include PIV (2D PIV) with spatial resolution of 3.2 ××3.2 (digital resolution of 6. 2 5 μm/pix) and long range microscopic particle tracking velocimetry
(2D PTV) with spatial resolution of 1.7 ××1.7 (digital resolution of 2.3 μm/pix). The 3D techniques include tomographic particle image velocimetry (tomo PIV) and three dimensional PTV (3D PTV) both carried out at high digital resolution of 7.5 μm/voxel (M 0.9) and tracer density of 0.015 particles per pixel. The spatial resolution of the t omo PIV is 22 × 22 × 22 (0.36 × 0.36 × 0.36 mm 3 and wall normal spati al resolution of 3D PTV is 5.5 (90 μm) The measurements are compared with channel flow direct numerical simulation ( of Moser et al ( at Re τ 180. The 2D PTV technique shows maximum uncertainty of 0.06 pix in resolving mean velocity and 0.1 pixel uncertainties in measurement of Reynolds stresses. The high magni fication tomo PIV shows an uncertainty of 0.2 pix in resolving the mean velocity
while an uncertainty of 0.3 0.7 pixel in measuring peak value of Reynolds stresses. 3D PTV based on triangulation of particles demonstrated smaller uncertainty relative to tom o PIV and 3D PTV using MART reconstruction.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
