方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
用德国LaVision公司的DaVis8.1.3软件平台中的PTV分析功能,对二维剪切流中的拉格朗日相干结构用拉格朗日粒子跟踪方法进行了识别分析研究。
The quantification of Lagrangian Coherent Structures (LCS) has been investigated using a novel algorithm based on the tesselation of unstructured data points. The applicability of such an algorithm in resolving an LCS was first tested using a synthetically-generated double-gyre flow with a known LCS solution. Subsequently, the algorithm was tested on experimental data acquired using two-dimensional particle tracking velocimetry (2D-PTV) of a nominally
two-dimensional free shear flow. To quantify factors linked to accurate LCS identification, dimensionless parameters are developed to characterize their relationship to LCS resolution. Specifically, the study considers turnover number (TN), which is defined here as the fraction of the particle track length to the vortical time scale, and cell ratio (CR), which can be thought of as the relative density of particles with long track lengths per characteristic vortex length scale. When examining the double-gyre finite-time Lyapunov exponent (FTLE) field, as expected, the resolution of the well-defined ridge improved with increasing TN. Upon use of tracks lengths >30% of the overall vortex time scale, only modest improvement in ridge resolution was observed. The LCS of the experimental data set was well-resolved using track lengths on the order of 20-30% of the vortex time scale. However, the use of greater TN values presented LCSs with an increasingly disordered coherence suggesting an inadequate particle count to accurately define the structure. Additionally, an exponential relationship was observed between CR and TN. This suggests that a compromise must be made between
track length and the density of tracked particles to adequately resolve an LCS where an insufficient number of particles have long track lengths.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
