方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | 其他 |
参考标准 | 暂无 |
用LaVision的图像增强器IRO,Imager Intense 相机和染料激光器构成了一套OH PLIF 自由基测量系统。对在反应流中产生的纳米颗粒特性进行了表征。
In this thesis, particle formation in reacting flows is investigated experimentally. Two separate systems are considered. First, silica particle synthesis is characterized in a cold, turbulent jet doped with trace amounts of silane gas that issues into a vitiated co-flow. Additionally, soot formation is characterized in a laminar ethylene diffusion flame.
Laser diagnostic techniques are the cornerstone of this work and make it possible to perform measurements with minimal disruption to the system. In both scenarios, elastic light scattering (ELS) and OH-PLIF are employed to obtain experimental signals that contain information about temperature, particle formation, OH concentration and other physical quantities. Additionally, line-of-sight extinction is used in the soot-forming system to recover integrated soot volume fraction profiles and multi-angle light scattering (MALS) is demonstrated on the silica-forming system to obtain in-situ information about particle size.
Laser-based datasets are supplemented by probe measurements, including temperature profiles measured using radiation-corrected thermocouples and TEM analysis of particle samples obtained by location-specific thermophoretic sampling.
Fully-defined numerical models, available in both scenarios, are validated following an unconventional approach based on the comparison of “predicted signals” with experimentally-obtained signals, as a means to avoid introducing additional assumptions.
Satisfactory agreement is found, even though some discrepancies remain concerning silica particle formation, which are likely related to uncertainties in precursor chemistry and nucleation. Nevertheless, this is one of a few joint numerical and experimental studies that address particle formation under turbulent conditions. Regarding soot formation in laminar flames, a consistent underprediction of soot formation on the centreline is identified, which is believed to be a limitation of the acetylene-based model.
In summary, this work uses optical diagnostic techniques to generate extensive datasets of particle-forming reacting jets, making a major contribution towards the validation of computational tools to predict particle formation in turbulent reacting flows as well as soot formation in laminar flames.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
