方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
双路染料激光构成的多参量激光诊断系统。进行了CARS/CO-LIF/磷光测温/OH-PLIF组合测量,CH2O-PLIF 和 OH-PLIF同时测量,以及拉曼测量尝试。研究了火焰壁面相互作用
Flame quenching resulting from flame-wall interactions (FWIs) is important in several
thermochemical processes of practical relevance, such as internal combustion engines. Even though FWIs are restricted to regions close to walls of a combustion chamber, they are crucial for wall heat fluxes and unburned hydrocarbon emissions. This experimental work is intended to investigate parametric sensitivities that influence flame quenching at walls and to better understand the influence of non-adiabaticity upon the flame structure. This work uses quantitative and semi-quantitative laser-based diagnostics with high temporal and spatial resolution simultaneously. Experiments are performed on a generic burner with side-wall
quenching configurations, where a branch of a V-flame interacts with a laterally oriented wall. Laminar and turbulent boundary conditions are generated for various wall temperatures and two different fuels (methane and dimethyl ether). To investigate the influence of wall heat flux on flame quenching, coherent anti-Stokes Raman spectroscopy (CARS) and phosphor thermometry are combined. From the measurements, gas and wall temperature profiles, wall heat fluxes and quenching distances are deduced and correlated. A further measurement of thermochemical states that provide the opportunity to look at the flame dynamics with flame
chemistry. The simultaneous measurement of CARS (for the gas temperature) and laser-induced fluorescence (LIF) of carbon monoxide (CO) (for the CO concentration) are applied. Above all, an influence of the time scales of heat transfer on CO chemistry is shown. Furthermore, simultaneous planar LIF of the formaldehyde molecule and the hydroxyl radical are used to image local heat release rate (HRR) distributions. In the turbulent case, flame fluctuations prevail in the FWI zone and are analyzed statistically regarding flame curvature. The correlation of heat release rate, flame curvature and wall-normal distance is investigated using the instantaneous HRR images for different wall temperatures and equivalence ratios. Finally, the feasibility study of the near-wall Raman spectroscopy is carried out. Raman
spectroscopy is a promising technique to quantify combustion-related species simultaneously.
However, especially near the wall, scattering and reflections from the wall are even higher than that of the other measurement techniques. The purpose of this feasibility study is to characterize the Raman signal quality near the wall. The resulting signal-to-noise ratio is found to be suitable for further measurements.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
