方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的图像增强器IRO和DaVis8.3软件平台,搭建一套利用甲苯作为测温标的物的示踪PLIF-测量系统。并利用该系统对热边界层的温度场分布进行了实验测量和分析。
An experimental arrangement of toluene-based Planar Laser Induced Fluorescence
(PLIF) has been developed and applied to the study of free and impinging jets formed with
air. In the toluene-based PLIF experiment, the flow is seeded with toluene particles and is
illuminated using a laser light sheet. The high-temperature dependency of the toluene fluorescence signal and the temperature induced redshift of the toluene fluorescence spectrum, nominate it for quantitative thermometry applications. The toluene molecules are excited by absorbing a resonant photon from the laser and as a result fluoresce spontaneously. The fluorescence provides useful information such as the concentration and
temperature of toluene particles and their surrounding environment. Two-color thermometry, with a single excitation wavelength (266nm) and camera image detection, is established for quantitative thermal characterization in this study. Simple free jets have been investigated to lead to refined data collection and data reduction. Time averaged, temperature profiles for the turbulent, free jets are obtained for jet Reynolds numbers of 5000, 10000, and 15000. To further validate the experimental technique, the jet temperature was varied from 300 K to 375 K. With the proposed data reduction methods, the PLIF technique was applied to a single impinging jet to assess both thermal flow field over a surface and convective transport from the surface. The PLIF method was validated against locally averaged Nusselt numbers using a traditional heat transfer calculation. PLIF results prove that PLIF can be applied to turbulent, near wall flows, where traditional methods are not able to non-intrusively measure the temperature gradient.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
