方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的DaVis8.4软件平台,结合脉冲Nd:YAG激光器,CCD相机和ICCD相机,构成了一套同时测量喷雾流体速度场和浓度场的测试系统。并利用这一系统对湍流多组分喷流中流速和标量浓度进行了测量,并分析了不对称性和浮力效应。
Buoyancy effects and nozzle geometry can have a significant impact on turbulent jet
dispersion. This work was motivated by applications involving hydrogen. Using helium
as an experimental proxy, buoyant horizontal jets issuing from a round orifice on the side
wall of a circular tube were analysed experimentally using particle image velocimetry
(PIV) and planar laser-induced fluorescence (PLIF) techniques simultaneously to provide
instantaneous and time-averaged flow fields of velocity and concentration. Effects of buoyancy and asymmetry on the resulting flow structure were studied over a range of Reynolds numbers and gas densities. Significant differences were found between the
centreline trajectory, spreading rate, and velocity decay of conventional horizontal round
axisymmetric jets issuing through flat plates and the pipeline leak-representative jets
considered in the present study. The realistic pipeline jets were always asymmetric and
found to deflect about the jet axis in the near field. In the far field, it was found that the
realistic pipeline leak geometry causes buoyancy effects to dominate much sooner than
expected compared to horizontal round jets issuing through flat plates.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
