方案下载应用领域 | 能源/新能源 |
检测样本 | 煤炭 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的高速时序控制器,高速图像增强器HS-IRO,高速相机搭健了一套可以进行高速示踪激光诱导荧光,纹影,米氏散射成像,高速甲醛激光诱导荧光,OH自发荧光和纹影成像等测量的系统,并对双燃料燃烧系统中先导燃料点火,燃烧和碳烟形成过程进行了实验表征研究
In recent years, many natural gas-fueled engine concepts have emerged for transportation, as well as stationary applications. They seem as an attractive solution to meet current and upcoming emission legislations at uncompromised eciency. Furthermore, the application of natural gas is advantageous regarding the associated CO2 reduction, high resistance
to auto-ignition (knock), and low sooting propensity. Especially in the large engine applications ranging from heavy-duty to marine and stationary, the lean burn combustion systems with a potential for lower pollutant emission at simultaneously higher than diesel-engine eciencies are employed. Advanced ignition systems like pilot ignition dual-fuel or pre-chamber spark ignition are utilized to ensure stable and fast combustion.
The dual-fuel combustion process is highly complex, involving short transient pilot-fuel injection into the premixed gaseous fuel charge, autoignition, and combustion mode transition into premixed flame propagation. Despite many advantages, the dual-fuel engines in gas operation often exhibit a tradeo of either (a) higher NOx and soot emissions or (b) high unburnt hydrocarbon emissions at deteriorated thermal eciency. This clearly elucidates the need for an improved understanding of the combustion process to support the development of advanced engine con-gurations and control systems, in order to achieve the design goals of fulfilling the present and future emission standards at highest possible thermal eciency. However, fundamental investigations of the dual-fuel combustion process are scarce.
The aim of this thesis was to advance the fundamental understanding of the dual-fuel combustion process. Characteristics of ignition, combustion, and the sooting propensity of a short pilot injection in compressed methane/air charge were investigated. Experiments were performed in an optically accessible Rapid Compression Expansion Machine, featuring quiescent charge throughout the cycle. A single-hole coaxial diesel injector mounted at the cylinder periphery was employed to admit the pilot fuel. The comprehensive measurement matrix includes variations of premixed charge (methane/air) equivalence ratio, pilot-fuel injection pressure and duration, as well as investigations at reduced oxygen charge content. Several cross-variations were performed.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
