方案下载应用领域 | 能源/新能源 |
检测样本 | 煤炭 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的高速图像增强器HS-IRO,Photron SA1.1 高速CMOS相机,以及SIRAH Credo型高速染料激光器,构成了一套时间分辩高速平面激光诱导荧光测量系统。并用这套系统研究了声学驱动非预混火焰接近吹熄状态的动力学过程
The effect of forced oscillations on the behaviour of non-premixed swirling methane flames close to the lean blow out limits was investigated using experiments in a lab-scale burner. Two different fuel injection geometries, non-premixed with radial -NPR- and non-premixed with axial -NPA- fuel injection, are considered. The flame behaviour is studied using 5 kHz OH∗ chemiluminescence and OH Planar Laser Induced Fluorescence (OH PLIF) imaging. In both systems, acoustic forcing reduces the stability of the flame, and in particular, the stability was found to decrease with the increase in forcing amplitude. Flame lift-off was observed in both configurations, with the magnitude of the effect of forcing depending on the fuel injection configuration. The results provide insight on the effect of superimposed flow field fluctuations in systems operating close to the lean blow out limits and offer useful data for the development and validation of numerical models for the prediction of the dynamic behaviour of flames of industrial interest.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
