方案下载应用领域 | 能源/新能源 |
检测样本 | 煤炭 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的高速图像增强器HS-IRO,Photron SA1.1 高速CMOS相机,以及SIRAH Credo型高速染料激光器,构成了一套时间分辩高速平面激光诱导荧光测量系统。并用这套系统研究了引燃对湍流火焰结构的影响
Pilot flames are commonly used to study turbulent flames as they present a means of preventing blow off at higher velocities. There are open questions regarding how pilot flames affect the main flame. This is true for both anchoring pilots, which are small pilot flames located at the base of the flame, and back-support pilots, which produce adiabatic or superadiabatic boundaries around the flame. The question of how the presence and size of pilot flames affect the properties of the main flames is important to understanding the behavior of the main flame. The purpose of this study is to explore how the presence of pilot flames affects the flame surface density, global consumption speed, and flame curvature statistics of a turbulent, premixed flame over a range of velocities. Natural gas was used as a fuel and the equivalence ratio was held constant at 1. Three different pilot flame configurations were used to explore the interaction between flame and pilot, including variations in the presence of both the anchoring pilots and the back-support pilots. The results of this study will affect our interpretation of flame sheet dynamics in a range of piloted flames.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
