方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的DaVis8.4软件平台搭建了粒子成像PIV,粒子跟踪测速PTV和平面激光诱导荧光测量平台。并用此平台对分层液-液管流与横流中的射流相互作用进行了测量和研究。
At low velocities, horizontal liquid liquid flows undergo gravitationally induced stratification which in many practical applications complicates significantly the direct measurement of the average properties of the flow. The extent of flow stratification however, can be limited through inline mixing leading to the formation of liquid liquid dispersions with more homogenous properties In this work we focus on the use of a ctive mixing methods using jets in cross flows JICFs In this paper, a dedicated experimental flow facility for the investigation of such flows is presented along with the accompanying laser based optical measurement
techniques and asso ciated algorithms that have been developed for this investigation The facility allows simultaneous, space and time resolved phase and velocity information to be generated via planar laser induced fluorescence ( and particle velocimetry (PIV/ with stereo PIV used to provide information on the third (out of plane) velocity component. Preliminary experimental results are presented which demonstrate the capabilities of this arrangement for optically examining stratified liquid liquid flows interacting with JICFs, leading to new insights into these complex flows The key results include phenomena of jets interacting with the liquid- liquid interface, recirculation zones that lead to further mixing, the presence of complex compound droplets, droplet size distributions and water concentration profiles.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
