方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的sCMOS相机,图像增强器IRO,可编程时间控制单元PTU构成了一套OH,HCHO激光诱导荧光PLIF和粒子成像测速PIV联合测量系统。并将之用于湍流预混旋流火焰的测量和研究之中。
This paper reports on the investigation of coherent structures in a high-swirl jet with vortex breakdown (Re = 5 000) and combustion of a methane/air mixture (with equivalence ratio equal to 0.7 and 1.4). The measurements were performed by combined application of the stereo PIV, OH PLIF and HCHO PLIF techniques. The velocity data were processed by the proper orthogonal decomposition (POD) and the PLIF data was conditionally sampled according to the POD correlation coefficients. For the non-reacting jet and lean flame, the POD has revealed presence of a coherent structure, consisted of helical vortex structures in the inner and outer mixing layers. Based on the PLIF data it was found that the inner spiraling vortex structure was correlated with positive fluctuations of the local heat release.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
