方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的图像采集和处理软件平台DaVis以及高速相机记录了无约束旋流稳定火焰的HO*自发辐射荧光,并和激光干涉测振方法相结合,研究了燃烧过程的放热波动现象。
Fluctuations in heat release, hot and cold spots convected by the flow and sound waves are all related to density fluctuations, a number easily detected by interferometry. Same as chemiluminescence, inter- ferometry is a line-of-sight method and therefore needs optical access and tomographic reconstruction of density fields. In this work we discuss the use of Laser Interferometric Vibrometry (LIV) as an alternative or extension to chemiluminescence when detecting heat release fluctuations in the flame, convection of hot and cold spots in the non-reacting flow field and sound waves emitted from a 3.4 kW turbulent, unconfined swirl-stabilized methane/air flame under perfectly premixed conditions. For this discussion local temperatures, local ratios of heat release and local Gladstone-Dale constants are determined and their influence on the result discussed. Global and local fluctuations in heat release rate recorded by LIV and chemiluminescence are compared, resulting in the same global values if local temperature fields and local equivalence ratios are used for LIV data evaluation. In contrast, local fluctuations in OH ∗chemilu- minescence emission are influenced by turbulence and strain in this type of flame.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
