方案下载应用领域 | 能源/新能源 |
检测样本 | 煤炭 |
检测项目 | |
参考标准 | 暂无 |
用Lavision的HSS5型高速相机和图像增强器IRO,高速染料激光器搭建了一套时间分辨激光诱导荧光测量系统,并用它来测量了10kHz的OH和CH2O的信号。对自燃过程在湍流火焰稳定中作用进行了实验研究。
This thesis presents experimental and complimentary numerical results based on a turbulent jet in a hot coflow burner (JHC). The thesis focuses on understanding and exploring the relative importance of autoignition in the flame stabilisation process for the conditions, temperatures and fuels considered. The influence of fuel type is explored using a range of gaseous fuels including: alkanes, alkenes, H2 and dimethyl ether (DME). High-speed (10 kHz) measurements of chemiluminescence and sound are applied to all flame cases, for all fuels, the measurements are used to temporally resolve the interaction of the flame base with ignition kernels. Similar flame-base and ignition kernel interaction characteristics are found for all fuels where the formation and merging of rapidly growing ignition kernels stabilise these flames. A measurement campaign employing 10 kHz OH and CH2O Planar Laser Induced Fluorescence combined with volumetric chemiluminescence imaging is applied to the ignition kernel formation region in DME flames. The measurements identify regions of low and high-temperatures respectively, with their spatial overlap representing heat release. The kernel heat release measurements indicate that differing degrees of autoignition stabilisation occurs for DME flames, specific to high and low coflow temperature flames. High coflow temperature flames produce lower heat release ignition-kernels; hence these flames are believed to have reduced dependence on autoignition for stability.
Zero-dimensional and one-dimensional numerical simulation results, obtained in this thesis, agree with the findings from the hot coflow experiments. The 0-D ignition delay times are shown to successfully capture the different fuels lift-off height sensitivities with coflow temperature. The sensitivity of relatively low coflow temperatures are particularly well represented by delay times, with a linear correlation between delay times and experimental lift-off heights. To replicate the strained and diffusive conditions induced by the JHC burner, unsteady 1-D counter-flow simulations were applied. These simulations, using DME, identify that for high coflow temperature flames, the ignition kernels produce lower heat release, since they are igniting leaner. Using CH4 with the same counter-flow setup, the effect of strain-rate was explored. It was found that increased strain rate delays ignition, since the unity balance between diffusion and production fluxes of CH2O is also delayed. Furthermore, under autoignition conditions, the counter-flow solver, in addition to a premixed solver, show CH2O convection and production fluxes increase, with a corresponding diffusive decrease.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
