方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司DaVis8.4图像采集和分析软件平台,可编程时间控制器PTU和高速相机,红外相机,构成一套可以用双色法,红外法测温,以及粒子图像测速系统,测量了水池沸腾过程的温度和速度场。
We study nucleate pool boiling in water at saturation temperature and ambient pressure under low heat fluxes. A combination of high-speed and spatially-resolved diagnostic tools are developed and applied to provide detailed insight into the flow and heat transfer mechanisms during bubble life cycle. Two fluorescent dyes with non-overlapping spectra are seeded into the water and are excited by a Nd:YLF laser sheet at 527 nm. A two-colour laser-induced fluorescence method is employed to individually track the fluorescence of each dye by connecting two cameras, equipped with separate optical filters, to a beamsplitter and a lens. Tracer particles are also introduced in the water to perform simultaneous particle image velocimetry measurements. Finally, synchronised high-speed infrared thermometry is conducted to acquire the surface temperature field over the heater. The links between the interfacial/bubble dynamics, flow and heat transfer are investigated. Superheated liquid
from the thermal boundary layer adjacent to the heater is displaced upwards, due to the growth and departure of the bubbles. Two counteracting vortices form on each side of the bubbles during their departure and rise, which contribute to the scavenging and mixing of the bulk water, resulting in a trail of superheated liquid below them.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
