方案下载应用领域 | 能源/新能源 |
检测样本 | 煤炭 |
检测项目 | |
参考标准 | 暂无 |
用LaVision的高速图像增强器HS-IRO和Photron, SA5型高速相机,建立了一套时间分辨高重复频率平面激光诱导荧光和粒子成像速度场联合同步测量系统,并利用这一系统研究了膨胀火焰结构与特性。
To predict combustion instability, the study of the flame surface is necessary because there is a relationship between the heat release rate and the flame surface. Combustion instability is occurred and amplified when the three components of the perturbation constitute a positive feedback. Thus each of three components should be considered carefully. In order to predict the combustion instability, in this paper, the unique flame structure, called as ‘the puffed flame’, was investigated. In the previous work, Kim et al. [1] discovered the puffed flame structure at the specific forcing frequency and the velocity perturbation region. In this paper, therefore, we revealed the causes and the dynamic characteristics of the puffed flame. Thus, simultaneous OH-PLIF and PIV measurements were conducted.
In case of the flame, the burke-schumann flame, a special case of the nonpremixed flame, was considered. The mixture of the methane and hydrogen was used as the fuel, and the air was used as the oxidizer. The acoustic forcing was applied for the several frequency region; from 100 Hz to 180 Hz with 20 Hz steps. Also incoming velocity perturbation amplitude was varied from 0.1 to 0.5 with 0.1 steps.
The velocity, strain rate, and the distribution of the OH radical were measured at the same time due to the simultaneous laser diagnostics. From these results, the response characteristics and the flow behavior were found at the exact same time. Flame structure was captured from the OH-PLIF measurement and the other quantitative results such as velocity vector and strain rate field were measured from the PIV.
In the same forcing frequency region, the flame puffed phenomenon was occurred over the specific velocity perturbation amplitude. If the forcing frequency became higher, the more velocity perturbation amplitude was necessary for the flame puffed. With this results, we could realize that the flame acts as a low pass filter. Also, it was revealed that the flame puffed
phenomenon was periodic process which was following the external acoustic excitation wave.
With the simultaneous PIV and OH-PLIF results, we could find out the relative high strain rate and the oxidizer entrainment played important roles for the puffed process. High strain rate make flame wrinkle and flame throat more thinner. As the process proceeded, more higher strain rate was applied to the flame surface as well. At the final stage of the flame puffed phenomenon, highly irregular flow was generated, so that the strain rate became much higher.
Meanwhile, oxidizer entrainment could be another reason for the puffed flame. During the process, surrounding air was continuously invaded into the middle of the flame. At last, flame was separated into two regions due to the entrainment of the surrounding air.
When the flame puffed phenomenon was occurred, the dynamic characteristics became different from the non-excitation flame case. The flame length became more smaller and the flame surface area also decreased. However, flame length and the surface area perturbation were increased. In other words, when the flame puffed, we could say that the flame became
more unstable.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
