方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的图像采集和处理软件平台DaVis8为核心,构建了一套激光诱导荧光火焰测量分析系统。并利用这套系统,进行了基于OH-PLIF技术的CO2稀释环形燃烧器预混火焰燃烧的实验研究。
In view of the combustion characteristics of annular chamber of micro gas turbine, a planar laser-induced fluorescence (PLIF) technique was used to investigate the methane/air premixed turbulent multiple flames in the annular combustor and the effect of CO2 on the characteristic parameters of flame structure was further discussed. The results show that the distribution of the OH radicals exhibits a ring structure with flame lift and bifurcation phenomena. The instantaneous and average image of OH-PLIF reveals that the multiple flames have the common characteristics of turbulent and laminar premixed flame structure. The quantitative analysis of the characteristic parameters of flame structure shows that
the increase of CO2 concentration, the flame premixed conical structure is stretched, the overall flame chemistry reaction area is reduced and the intensity of local combustion is weakened; The Coanda effect causes the flame to bend towards the inner wall, and the relative bending of the outer flame increases as well as the flame angle.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
