方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium 公司的PDI-200型相位多普勒粒子干涉仪,对燃气轮机燃烧室新型双相空气喷射器喷雾的液滴粒径和SMD的空间分布及其与燃料的位置关系进行了实验测量研究。
A novel airblast injector is designed for gas turbine combustors. Unlike standard pressure swirl and prefilming/non-prefilming air blast atomizers, the novel injector has a porous stainless steel tube with 7um porosity. The porous tube is used to inject the fuel between two air streams. The advantage of such an injector is that it can increase the surface area of contact between the fuel and air by forming a thin liquid sheet along the circumference of the tube which will enhance the distribution the fuel more effectively, and produce a fine spray at engine idle conditions. The injector can also be used to inject simultaneously both liquid and gaseous fuels. An experimental approach is adopted in the present study to characterize initially the spray and fuel placement emanating from this injector. The fuel injector consists of two streams of air, viz. through inner section of the tube and another swirling stream merging downstream of the tube. Jet-A fuel is injected through the surface of the porous tube. Due to the permeability of the tube, a thin liquid sheet is produced along the tube which is atomized by the inner airstream by surface stripping of the liquid sheet. Further, a secondary breakup occurs downstream of the tube. The swirl vane angle and air split are selected to increase the amount of air through the tube and enhance the atomization. Flow visualization studies show a hollow conical spray. Patternator tests are carried out to study the fuel distribution and symmetry of the spray. The results show a hollow cone spray with asymmetric distribution of volume flux. Spray characterization is further car-ried out with PDPA at selected operating conditions. The measured SMD shows that the atomization is reasonably good with wide fuel placement downstream of the atomizer at atmospheric conditions.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
