方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium 公司的PDI-200MD型相位多普勒粒子干涉仪,水喷雾中的乙烯 - 空气爆轰的液滴粒径和D10,D32,液态水含量等参数实验测量研究。
In this paper, we present an experimental work on the influence of liquid water spray in an ethylene/air gaseous mixture on detonation, for equivalence ratio from 0.9 to 1.1.
Spray detonation investigations has nowadays a strong interest in propulsion by establishing mixture detonation parameters for PDEs and RDEs to design detonation chambers, and also in hazard prevention, by knowing quenching specifications for hazardous mixtures.
Early studies on spray detonations have been performed by Dabora and Raglands ([1], [2]), showing the influence of large droplet size (from 290 to 2600m) desintegration, vaporization and combustion mechanisms on the detonation propagation. Mar [3] exposed that the detonability range is all the wider the droplets are small (with droplets from 9.5 to 45 m). Besides, investigations on detonation quenching with water spray injection (200-750 m droplets, spray densities of 0.72-1.6 kg=m3), in a H2/O2 stoechiometric mixture diluted with Ar, revealed that it is more efficient with a fine spray (200 m) [4]. A 10% velocity deficit in comparison with the CJ speed has been observed for an initial pressure of 20kPa.
Numerical works on detonation with solid particles also reveal interesting features about the twophase influence. Williams [5], showed the stability of liquid spray based detonation. Cheatham and Kailasanath [6] developed a numerical model for liquid-fuelled detonation in tubes. They show that preheating and prevaporization of small liquid droplets generate a faster transition to a self-sustained detonation. Fedorov et al. [7] studied a 2-D detonation in a C2H4/air mixture with solid inert particles. Significant velocity deficit, greater than 10 %, was shown for a fairly significant solid mass fraction Yinert 0:1, and even failure for Yinert 0:34, with 10 um particles.
But nevertheless, despite the amount of current works on spray detonations, few experiments on detonation quenching remain available.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
