方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司的PDI-300型相位多普勒粒子干涉仪,用AIMS软件测量除污过程中喷雾性能的实际状况并于CFD模拟的结果进行对比分析。
Heat exchangers are widely used in heating, air conditioning, refrigeration, industrial plants and refineries, gas pro-cessing and water treatment. Fouling is a chronic operating and design problem for retaining highly effective heat exchangers. This leads to countless chemical and mechanical attempts for reducing fouling. Mitigation of fouling and removal of deposits can be addressed efficiently with proper design and gas conditioning modification. All previous mentioned factors and uncertainties can be examined, evaluated and optimized by using computational fluid dynamics (CFD) simulation.
Typical defouling and cleaning process involves chemical solvent sprayed on the heat exchanger surfaces. Manufacturers and operators are facing increasing difficulty to preserve heat exchanger efficiency due to complex structures. Spray behavior and performance cannot be simply predicted due to the many variables involved such as nozzle characteristics, geometry, orientation, gas flow of heat exchanger and pressure resistance. There are tremendous challenges associated with fouling of heat exchangers, where CFD is known as a common tool to predict and resolve those problems. In this work, we will compare the performance of CFD simulation of spray with practical droplet test data in a scaled heat exchanger built and tested in Spraying Systems Co. spray laboratory for a pilot anti-fouling imitation. The spray characteristics based CFD will be used to validate the importance of reasonable and precise spray input simulation in a solvent based defouling process.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
