脉冲流场在USP溶解仪中引起的水动力复杂性
2019/12/03   下载量: 0
方案下载
应用领域 石油/化工
检测样本 其他
检测项目 其他
参考标准 暂无
采用LaVison公司的DaVis软件平台,通过阴影发成像和粒子成像测速分析,对脉冲流场在USP溶解仪中引起的水动力复杂性,进行了研究。
方案下载
配置单
方案详情
USP dissolution Apparatus 4 can have a pulsing or non-pulsing flow, with most commercial apparatus employing a pulsing flow. Overall, a low velocity flow field is present, particularly in the larger 22.6-mm diameter cell. Dissolution data, computational fluid dynamics (CFD), and imaging methods are used and discussed to investigate the effects of low velocity pulsing flow on dissolution. Local velocity patterns, density gradients, and the effect of flow rate on particulate dispersion can all contribute to the observed dissolution rate. In silico simulation tools and imaging techniques have proved useful in determining local hydrodynamics and, in some cases, their effect on observed dissolution rates. Methods to investigate concentration gradients at the dissolving surface are required to investigate further the effect
of hydrodynamics on the dissolution process. In conclusion, it is necessary to take local flow patterns and velocities into
account, rather than overall flow rate alone, when interpreting dissolution rate data in the flow-through apparatus.
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 离子表面活性剂体系的表面流变学研究,重点关注振荡气泡技术
文献贡献者
相关方案
当前位置: 欧兰科技 方案 脉冲流场在USP溶解仪中引起的水动力复杂性
