方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
利用LaVision的DaVis8.4软件平台构成的PIV系统测量了交叉流燃油喷射的速度场,同时测量了OH基自发辐射荧光分布,研究了交叉流燃油喷射对反应射流的影响。
The effects of cross-flow fuel injection on a slotted jet flame consisting of an ethylene-air premixture are investigated experimentally. Cross-flow conditions of 900 K and 100 m/s were chosen to closely simulate the environment of a secondary combustor in a staged combustion system. It was found that increasing the cross-flow equivalence ratio ( ∞ ) requires a consequent reduction in the jet equivalence ratio ( j ) for jet flame stabilization in order to avoid the formation of locally rich mixtures beyond the flammability limits of the flame. Stable flames were achieved for a low cross-flow equivalence ratio of ∞ = 0.4 across a range of jet equivalence ratio values and momentum flux ratios, demonstrating the ability of the trans- verse jet to extend the flammability limits of the cross-flow mixture. Significantly, as ∞ is increased beyond a certain point, no ethylene is required to be present in the jet mixture, and a jet consisting only of air is able to stabilize the flame. Due to the fluidic nature of the flame stabilization mechanism of these flames, they are dubbed fluidically stabilized flames (FSF). OH ∗chemiluminescence and high-speed particle image velocimetry were utilized to gain deeper understanding of the flame behavior and flow field features of the FSF. In contrast to bluff-body stabilized flames, it was found that the FSF provides increased control of the flame shape, with increasing flame width and penetration for higher jet momen- tum flux ratios ( J ). The FSF was also demonstrated to be a highly dynamical phenomenon, characterized by a dominant peak frequency that is dependent on both j and ∞ . Proper orthogonal decomposition of the time-resolved velocity fields shows that heat release affects the dynamics of the FSF in a similar manner to the reacting jet in cross-flow (RJICF), as demonstrated in a previous study. Finally, the flame behavior was found to be highly dependent on the cross-flow fueling mechanism, with coherent flame oscillations present when the fuel injection point is closely-coupled to the flame stabilization location.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
