方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的IRO和CCD相机构成的增强型CCD相机系统,对CH*的自发荧光图像进行了测量,研究了N2和CO2稀释对C3H8/O2混合气在涡流管式火焰燃烧器中的燃烧特性的影响。
Premixed C3H8/O2 combustion has been investigated by adopting N2, CO2 and their mixture (50% N2-50% CO2 by volume) as the diluents, respectively. The oxygen content (mole fraction) in the oxidizer is varied from 0.13 to 0.35, which covers the operating conditions of EGR and OEC. The flame structures, temperatures, burning velocities and NOx emissions are examined under various oxygen contents. Detailed observations show that a
steady, uniform tubular flame can be obtained over a wide range from lean to rich. By increasing oxygen content, the flame diameter increases slightly; the flame length decreases significantly, which is almost inversely proportional to laminar burning velocity. During decreasing the burning velocity to less than about 20 cm/s, a turning point appears and the flame length becomes extensively large. With the same oxygen content and equivalence ratio, by replacing half or all of the N2 diluent with CO2, the flame temperature and burning velocity decrease significantly. To obtain the same adiabatic flame temperature, the CO2 diluted mixture requires the highest oxygen content among the three diluents, however, its measured flame temperature is also highest. In the N2-CO2 diluted combustion, owing to thermal and chemical effects of CO2, the NOx emission reduces remarkably comparing with N2 dilution; under the same flame temperature, the NOx concentration reduces to almost 1/5 of that diluted by N2. The lean extinction limit raises by increasing CO2 content in the diluent, while the limit decreases with increasing oxygen content.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
