方案下载应用领域 | 石油/化工 |
检测样本 | 聚丙烯(PP) |
检测项目 | 机械性能 |
参考标准 | 暂无 |
采用LaVision形变应变分析测试系统StrainMaster对水化钢包渣和石膏的应变硬化聚丙烯纤维增强复合材料的效应进行了测量和分析研究。
The use of industrial by-products brings both economic and environmental benefits. Ladle slag (LS) from steel processes is a promising raw material and has been used as a precursor in a few studies. To better understand the benefits of LS mainly on mechanical behavior, in this investigation, an ettringite-based binder was produced from the hydration between LS and gypsum. The material was reinforced with 2% v/v high tenacity polypropylene (HTPP) fiber to attain a high performance fiber reinforced cementitious composite with pseudo strain
hardening (PSH) behavior. In addition, results of FEM numerical analysis show the accurateness of an available constitutive model in predicting the mechanical response of the HTPP fiber reinforced hydrated LS composite. Additionally, the experimental results reveal that using HTPP fiber greatly enhanced the mechanical properties of the hydrated LS. Moreover, PSH behavior and eventually multiple fine cracks were recorded by the digital
image correlation (DIC) technique under uniaxial tensile tests. The numerical simulations show the capability of the concrete damage plasticity (CDP) model to predict the nonlinear behavior of the material with a good agreement between experimental and numerical predictions.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
