方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的PLIF平面激光诱导荧光火焰自由基分析测量系统,对中等尺度燃烧器阵列燃烧是产生的甲醛,CH,OH等自由基浓度的空间分布进行了测量研究。
Combustion characteristics of a mesoscale burner array have been studied using several diagnostic and analysis techniques. The array was specifically configured to enhance overall combustion stability, partic- ularly under lean operating conditions, by promoting flame to flame interactions between neighboring elements. The 4 ×4 burner array demonstrated stable operations up to 3 kW and is designed to flexibly accommodate wide range of combustion power outputs by scaling the element dimensions or array size. Flame stabilizing mechanisms were experimentally examined using OH, CH, and CH 2 O planar laser in- duced fluorescence (PLIF) of premixed CH 4 and air flames at operating equivalence ratios between 0.7 and 1.2. A quantitative measure of flame stability was obtained through dynamic mode decomposition (DMD) analysis of high speed OH-PLIF images. Lean blow offlimits and emissions were also character- ized across a wider range of equivalence ratios to better understand mesoscale burner array combustion characteristics. Lastly, combustion experiments using liquid fuel, pentane (C 5 H 12 ), were also carried out. Marked improvement in combustion stability was observed compared to a single swirl-stabilized flame of similar power output. Results indicate mesoscale burner arrays can potentially serve as flexible and scalable next generation propulsion and power generation systems.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
