方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Laser-Induced Incandescence (LII) occurs when a high-energy pulsed laser beam encounters graphitic particulate matter particles like soot or carbon black. The particles absorb laser energy from the beam and see an increase in their internal energy, resulting in an increase of temperature. At the same time, the particles loose energy through heat transfer mechanisms. If the energy absorption rate is sufficiently high, particle temperature will rise to levels where significant incandescence (blackbody emission) can occur .Typically, Laser-Induced Incandescence produces 50ns to 1μs long light pulses at atmospheric pressure. So far, LII measurements had been restrained to conduction-dominated conditions, whereby signals are short-lived (less than one microsecond) and require sensitive nanosecond resolution instrumentation. This thesis introduces a novel LII – based measurement method performed under high vacuum conditions. The novelty of LII under vacuum resided in the fact that heat conduction away from the soot particle becomes negligible below 10-2 mbar and this constituted a step away from the typical situation, whereby laser absorption is followed by heat conduction from the particles to the surrounding medium. Instead, sublimation and radiative heat transfer would follow laser absorption. The consequence was the obtention of long-lived LII signals (up to 100 microseconds) and a large gain of photons (ranging between 50 to 300) emitted per primary soot particle during LII temperature decays. Furthermore, the refractive index function E(m) value could be determined directly from measured radiative temperature decays, with potentially an uncertainty of circa 7%, which outperformed current soot extinction measurements. In addition, for laser fluences below 0.06 J/cm2, a regime where only laser energy absorption and radiative heat transfer apply would be reached and LII signals became independent of particle size.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
