方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Numerical simulations of particle image velocimetry (PIV) experiments con- ducted with vortex generating jets (VGJs) on a °at plate, at a Reynolds number based on plate length of 50,000, were performed for three °ow conditions using a time-accurate hybrid Navier-Stokes solver. Time-averaged steady blowing of angled jets, subjected to a zero pressure gradient, yielded excellent agreement with the PIV data in terms of vortex formation and strength. Observed °ow features include pri- mary and secondary vortices, where the primary vortex eventually dominates the downstream region. A shell wall structure, created by smaller vortical structures sur- rounding the developing vortices, was also observed. A pulsed jet in a zero pressure gradient was then initialized from a no-control case. A qualitative comparison be- tween averaged experimental and instantaneous numerical results was performed with good agreement in terms of the convected size and distance of the wake. Analysis of the instantaneous numerical °ow ¯eld agreed well with various °ow visualization experiments describing the formation of \kidney" vortices. Various indicators point to the production of a primary vortex by the reduced mass °ow of the pulsed jet. Finally, an adverse pressure gradient was applied, inducing a laminar separation zone on the plate. A pulsed angled jet induced strong spanwise vortices in the separated shear layer which appear to weaken the separation zone and allow the bulk jet °uid to °ush the remaining low-momentum °uid out of the domain. It is reasonable to assume that reduced blowing ratios and duty cycles would produce similar shear layer vortices and comparable loss reductions. In°uences of both turbulent transition and dominant vortical structures were observed, though the spanwise shear layer vortices appear to be critical to the laminar separation reduction scenarios observed in this study.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
