方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The distortion, drag and break-up of drizzle droplets subjected to strong aerodynamic forces was investigated to understand the pre-impact behaviour of droplets in aircraft icing from supercooled freezing drizzle. The objective was to obtain a formulation and data for the drag properties of droplets distorted by the aerodynamic forces, which were beyond the scope of available experimental and modelling methods. A practical and efficient semi-empirical computer model was developed for small water droplets in air, 100μm < D < 500μm, at moderate Reynolds numbers, 350 < Re < 1500, and high Weber numbers 3 < We < 20. This used available experimental terminal velocity data for free-falling droplets, extrapolated to higher Weber numbers, and the numerical solution for sessile droplets on a horizontal unwettable surface, with corrections for the Reynolds number.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
