方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | Application Note |
The Park AFM provides highly sensi-tive force-distance data to observe interactions between single mole-cules through the low-noise control of the Z scanner movement. The force-distance results enable the assessment of binding interactions between single DNA molecules, RNA mole-cules, and proteins.
利用原子力显微镜对二维异质结构上莫列波纹的研究
利用导电探针原子力显微镜(CP-AFM)测量碳纳米管薄膜导电性
利用AFM PINPOINT 纳米机械模式定量材料的弹性模量 比力体积谱快两个数量级
