http://www.kyoto-kem.com Measurement of mercaptan sulfur and hydrogen sulfide 1 PPM can be detected by titrator with lower cost than any other technologies!! Determination of mercaptan sulfur and hydrogen sulfide in fuels and liquidpetroleum gases (LPG) is one of the important applications in the latestpetroleum/gas analysis. According to international standard methods, 1 ppm level as minimumdetection level can be confirmed with titration method. International standards ■ ASTM D3227 Standard Test Method for (Thiol Mercaptan) Sulfur in Gasoline,Kerosine, Aviation Turbine, and Distillate Fuels (Potentiometric Method)UOP 163 Hydrogen Sulfide and Mercaptan Sulfur in Liquid HydrocarbonsIP 272 Determination of mercaptan sulfur and hydrogen sulfide content of liquefiedpetroleum gases (LPG) Features of AT-700 Titrators Preset parameter Less investmentSpecial sealing cell & Special coating silver electrode Easy operation and maintenance Quick measurement The system makes the application successful with KEM special sealing cell and electrodes to avoid oxidization of mercaptan sulfer under atmosphere. Standard items AT-700 automatic potentiometric titrator Special sealing cell Special coating silver electrode Standard substance www.kyoto-kem.com Electronic record of measurement result & methodSoftware for method set-up Method set-up with the software installed PC Transfer of set-up method to memory of a main unit Choice of 1 or 2 built-in burette First end point (EP1) is hydrogen sulfide andsecond (EP2) is mercaptan sulfur. In case of IP272, it is necessary to be followed aprocedure and apparatus described in ASTM D1265. A lead acetate paper is recommended to check ifhydrogen sulfide is present before titration. Preset Parameters Method 11: Sample testing (2 EP points) with 0.01mol/L AgNO3 Method 12: Sample testing (2 EP points) with 0.001mol/L AgNO3 Method 13: Sample testing (1 EP points) with 0.01mol/L AgNO3Method 14: Sample testing (1 EP points) with 0.001mol/L AgNO3Method 15: Blank tirationMethod 16: Coating of silver electrode with AgNO3Method 17: Silver nitrate standardization for 0.01Mol/L AgNO3 Method 18: Silver nitrate standardization for 0.001Mol/L AgNO3Method 19:Verification with standard substance Range ·pH:-20.00~20.00pH ·Temperature:0~100℃ Titration Mode Auto/ Auto Intermit/ Intermit/ Stat Method Number 20 Kinds of Titration Acid-base/ Redox/ Precipitation/ Photometric/Polarization/ Conductivity Display 20 characters 6 lines LCD with backlight Display Content Potential/ Titration amount/ Measurement result/ Parameter Data Memory 50 samples Option Automatic burette/ CHA-700 Environment ·Temperature: 5~35℃ ·Humidity: Below 85%RH KGM KYOTO ELECTRONICS MANUFACTURING CO.,LTD.
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《硫醇中硫的含量检测方案 》,该方案主要用于其他中硫的含量检测,参考标准《暂无》,《硫醇中硫的含量检测方案 》用到的仪器有AT-710B 简易实用型自动电位滴定仪、AT-710S 豪华型自动电位滴定仪、AT-710M 四通道旗舰型自动电位滴定仪、酸值碱值溴值溴指数硫醇硫碱性氮盐含量测定。
