DataNo.RL09-06083电话:021-54488867 电邮: kemu-kem@163.com网址: http://www.kyoto-kem.net.cn KEM Application Note No.DAZ-06101Density Measurement Kyoto Electronics Manufacturing Co., Ltd. High grade ethanol -Measuring instrument- Main unit: DA-510 Density meter Option: Auto sampler CHD-500N 令 Connecting kit#434-0101 .Solvent- Rinse-1: water Rinse-2: acetone -Summary- Checked reproducibility of density measurement of high grade ethanol by DA-510+CHD-500N,and obtained good standard deviation of 0.00001g/cm(n=12). -Measurement method- 1. Measurement temperature was set to 20℃. 2. Calibration was performed with air and water. 3. The samples were put in vials and placed on the sampler rack. 4. Press [Meas.]key for measurement of density of the sample liquid. -Concentration conversion, temperature compensation formula- International alcohol table (OIML) is used for alcohol concentration conversion. -Ambient condition- Ambient: 22℃ Humidity: 50 % Weather: Fine -Literature- -Measurement parameter- -Measurement data- Method No. : 0 Method Name : EtOH 100 Temperature . 20.00℃ Stability : 1 Limit Time 0 s Sequence On Sampling Seq.: Auto Samp. Limit : 0 sec O.S. Rate : 70 % Drain Seq. Auto Drain Rate 200 % Rinse-1 Seq. : Set Rinse-1 Time : 10 s Rinse-2 Seq. : Set Rinse-2 Time : 10s Purge Seq. Auto Cell Test Off Calib. Air&Water Sample No. 01-01 Meas. Temp.: 20.00℃ Period T 1047828 d [g/cm3] 0.78967
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《全自动密度计测定乙醇的密度和酒精度》,该方案主要用于其他中null检测,参考标准《暂无》,《全自动密度计测定乙醇的密度和酒精度》用到的仪器有DA-6XX+RA-6XX全自动密度计折光仪组合系统、DA-650高精度数字式密度仪/比重仪、DA-645数字式密度计/比重计、DA-640数字式全自动密度计。
