Kyoto Electronics Manufacturing Co., Ltd.Data No.RV09-06061 No.RAZ-06079 K EM Application Note No.RAZ-06079 Refractive Index Measurement Refractive Index of Premium Ethanol ① Set the measurement temperature at 20℃. ② Perform calibration with dried air and pure water, respectively. ③ Put the sample in vials and set them onto the turntable of CHD-501N. CHD-501N ④ Press [Meas.] key to start measuring the index of refraction of the sample. FCU-510 -Rinse solution- -Equation- No equation is used. Ambient condition- Temperature: 22.5℃ Relative Humidity: 51% Weather: Fine -Reference- 京都电子工业株式会社-可睦电子(上海)商贸有限公司 上海市漕溪路222号航天大厦北楼902室 Method No. Method Name Temperature Stability Wait Time Sequence Sampling Samp. Limit O.S. Rate Drain Drain Rate Rinse-1 Rinse-1 Time Rinse-2 Rinse-2 Time Purge Purge Time ***Result* : EtOH 100 : 20.00℃ : 0 : 0 s : On : Auto : 0 sec : 10 % : Auto : 200% : Set : 10 s : Set : : 10sSet : 240s *: Sample No. 01-01 Meas.Temp. 20.02℃ nD 1.36129 ***Result*** Sample No. 01-02 Meas. Temp. : 20.02℃ nD : 1.36129 ***Result* Sample No. 01-03 Meas. Temp. 20.02℃ nD 1.36129 ***Result*** Sample No. 01-04 Meas.Temp. 20.01℃ nD : 1.36129 -Measurement results- Run Measured value Run Measured value 1 1.36129 13 1.36130 2 1.36129 14 1.36128 3 1.36129 15 1.36128 4 1.36129 16 1.36130 5 1.36129 17 1.36131 6 1.36130 18 1.36128 7 1.36129 19 1.36130 8 1.36130 20 1.36129 9 1.36129 2 1.36129 10 1.36129 1.36131 11 1.36130 23 1.36130 12 1.36128 24 1.36128 Statistics Mean 1.36129 SD 0.00001 RSD (%) 0.00066 -Comments- Nothing in particular. 京都电子工业株式会社-可睦电子(上海)商贸有限公司 电话: 电邮: kemu-kem@ com 上海市漕溪路航天大厦北楼网址: http://www.kyoto-kem.net.cn电话: 电邮: kemu-kem@ com
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《全自动折光率仪测定乙醇的折光率》,该方案主要用于其他中null检测,参考标准《暂无》,《全自动折光率仪测定乙醇的折光率》用到的仪器有RA-620/RA-600全自动折光糖度仪、DA-6XX+RA-6XX全自动密度计折光仪组合系统、RA-620高精度数字式折光仪、RA-130便携式折光率仪/糖度计、RA-600全自动台式折光仪。
