分析测试学报FENXICESHIXUEBAO (Joumal of Instrumental Analysis)第29卷第4期2010年4月Vo. 29 No. 4394~397 395第4期 李利军等:阳离子选择性耗尽进样-胶束电动色谱法对可非糖浆中盐酸异丙嗪与磷酸可待因的测定 阳离子选择性耗尽进样-胶束电动色谱法对可非糖浆中盐酸异丙嗪与磷酸可待因的测定 李利军,郝学超,李彦青,程昊 (广西工学院生物与化学工程系,广西杉柳州 545006) 摘要:在胶束电动色谱法的基础上,联用阳离子选择性耗尽进样技术,对盐酸异丙嗪和磷酸可待因同时测定的方法进行了研究。考察了 pH值、有机溶剂、SDS浓度、进样时间、进样电压等实验条件对分离效果的影响。最佳实验条件为:缓冲体系16%乙腈 +80 mmol/L SDS+20 mmol/L NaH,PO4 (pH 2.4),分离电压为-18 kV, 测量波长214 nm, 萃取液 pH 2.4, 进样电压10kV, 进样时间100s.在优化实验条件下,两种物质在8min内出峰,峰面积 RSD不大于 4.6%。盐酸异丙嗪、磷酸可待因的线性范围分别为0.50~81.3、0.78~62.5ug/L,检出限分别为 0.16、0.12p g/L,相关系数分别为0.998 9、0.9988.将方法用于可非糖浆中盐酸异丙嗪与磷酸可待因的测定,回收率为96%~106%。 关键词:毛细管电泳;阳离子选择性耗尽进样;胶束电动色谱法;盐酸异丙嗪;磷酸可待因 中图分类号:0657.7; R917 文献标识码: A 文章编号:1004-4957(2010)04-0394-04 doi: 10.3969/j. issn. 1004-4957.2010.04.017 Detemm ination of Promethazine Hydrochloride and Codeine Phosphate in CompoundCodeine Phosphate Syrup by Sweep ing M icellar Electrokinetic Chromatographyin Combination with Cation-selective Exhaustive Injection LILi-jun, HAO Xue-chao, LIYan-qing, CHENG Hao (Deparment ofB iological and Chem ical Engineering, GuangxiUniversity of Techno logy, Liuzhou545006, China) Abstract A sweep ing m icellar electrokinetic chromatography(MEKC) in combination with cation-se-lective exhaustive injection (CSEI) method was developed for the detemm ination of promethazinehydrochloride and codeine phosphateThe expermentalfactors, iincludingpH, concentration of ace-tonitrile, the effectof SDS concentration, sample injection time and injection voltage were op tim izedThe optimum conditions were as the follow s:buffer system:16% acetonitrile +80 mmol/L SDS+20mm NaHPO4 (pH 2.4), separationpot ntial -18 kV;detecting wavelength: 214 nm; eex-traction buffer pH 2. 4; sample injection voltage:10 kV:;iinjection time::100 sUnder the optimum conditions.,two substances were successfully separated with in 8 m inutes with the RSD s of peakarea less than 4.6%. The calibration plots were linear in the range of 0.50 -81.3pg/L forpromethazine hydrochloride, and 0.78-62.5p g/L for codeine phosphate Their correlative coeffi-cients were 0. 998 9 and 0.998 8, respectively, and their lim it detections were 0.16p g/L and 0. 12ug/L, respectively The proposed CSEI-sweep ingMEKC method was successfully applied for thedetection of p omethazine hydrochloride and codeine phosphate in compound codeine phosphate syrupw ith recoveries of 96%-106%. Key words: cap illary electrophoresis;; cation-selective exhaustive injection;l,sweep ing m icellar elec-trokinetic chromatography, promethazine hydrochloride; codeine pho sphate 盐酸异丙嗪和磷酸可待因是可非糖浆中的有效成分,但磷酸可待因的滥用会造成药物依赖性,严重者可导致肾功能障碍。药物中盐酸异丙嗪和磷酸可待因含量的测定方法有高效液相色谱法2-4]、胶束电动色谱法15-7]、荧光分光光度法[8-9]、电化学发光法[10-111等。本文在胶束电动色谱的基础上,联用 ( 收稿日期:2009-11-24;修回日期:2010-02-20 ) ( 第一作者:李利军(1966-),男,湖北黄梅人,教授,博士, Tel: 0772-2685028, E-mail: l ilijun0562@ sina. com ) 阳离子选择性耗尽进样,对可非糖浆中的盐酸异丙嗪和磷酸可待因进行测定。 阳离子选择性耗尽进样法2是在充满非胶束背景溶液的毛细管中,首先进一段不含胶束的高电导缓冲液区带,再进一小段水塞,然后在正向电压下电动进样,样品阳离子快速通过水塞并在水塞和高 电导缓冲液间的界面处聚集,形成窄的样品区带,然后在胶束缓冲溶液中施加负向电压分离。胶束进入毛细管并对样品离子进行扫集,实现样品的第二次富集。最后在此电压下进行胶束电动色谱分离。由于选择性耗尽进样法是样品堆积与扫集两种富集方法的结合,因此其富集效果大大增强,富集倍数高达1000倍以上113-15]。将本方法应用于可非糖浆中盐酸异丙嗪和磷酸可待因的分离测定,结果满意。 图1盐酸异丙嗪(左)与磷酸可待因(右)的分子结构图 Fig. 11NMolecular structures of p romethazine hydrochloride(left)and codeine phosphate (right) 1实验部分 1.1仪器与试剂 ACS 2000高效毛细管电泳(北京彩陆公司),未涂层毛细管(50m x69.0 cm,有效长度35.0 cm,大连三杰科技发展公司)。 DL-60D超声波清洗器(上海之信公司); Mettler toledo Delta 320酸度计(瑞士梅特勒托利多公司)。盐酸异丙嗪、磷酸可待因对照品(中国药品生物制品检定所);可非糖浆沈阳第五制药厂); NaH,PO4、Hg PO4、CH, OH(汕头西陇化工厂);十二烷基磺酸钠(SDS, 汕头光华化工厂)。以上试剂均为分析纯,实验用水均为二次蒸馏水。 准确称取盐酸异丙嗪 5.2 mg山磷酸磷待因 4.0 mg, 用20% CH,OH分别配成质量浓度为 520 mg/L和400 mg/L的对照品储备液。电泳缓冲液用 100 mmol/L NaH, PO4、200 mmol/L SDS储备液配制, pH值用85%(体积分数)H上 Po 调节。所有溶液进毛细管前均用 0.45um滤纸过滤,超声脱气。 1.2实验方法 先在毛细管中充入萃取液 (20 mmol/L NaH,PO4+16%乙腈, pH 2.4),再用正电源10 kV电动进样100 s, 切换电源后,采用负电源-18 kV电压进行分离。检测波长214 mm;实验室温度保持约25℃。 2结果与讨论 2.1电泳运行条件选择 为抑制电渗流,调整磷酸盐缓冲体系的 pH值为2.0~3.0。考察了不同 pH值、不同有机改性剂(甲醇、乙腈、异丙醇和乙醇)及不同分离电压对分离效果的影响。结果表明,当选用缓冲体系的 pH值为2.4,有机改性剂为16%乙腈,分离电压为-18kV时,两种化合物的峰形理想,出峰时间短,结果见图 2A、B。 图2pH(A)、乙腈体积分数(B)与 SDS浓度 (C)对峰面积的影响 Fig.2 Effect ofpH(A), volume fraction of acetonitrile(B) and concentration of SDS(C) on peak area 1.promethazine hydrochloride, 2. codeine phosphate; background electrolyte: A. 60 mmol/L SDS+20 mmol/L NaH2PO4+10%acetonitrile, B. 60 mmol/L SDS+20 mmol/L NaH, PO4 (pH 2.4),C. 20 mmol/L NaH,PO4 (pH 2.4)+16% acetonitrile 考察了 SDS浓度为 60~120mmol/L时两种化合物的分离效果。如图2C所示,随着 SDS浓度增加,峰增高,出峰时间缩短。这是由于 SDS增大了样品的容量因子。但过高的 SDS浓度会导致低导样品区带中形成的堆积区宽度增大,引起峰增宽。实验结果表明当SDS浓度为 120mmol/L时,出现明显的峰增宽峰高降低的现象。因此为保证稳定性,实验选择SDS浓度为 80mmol/L。 2.2胶束扫集进样时间的确定 考察了进样时间为40~80 s(H=18.0 cm)时样品的峰面积,结果表明峰高随进样时间的延长呈增大趋势。但由于进样时间大于60s时,基线稳定性明显变差,易出现杂峰,柱效下降,故选择进样时间为60 s 2.3 阳离子选择性耗尽进样 2.3.1萃取液的选择以20 mmol/L NaH, PO4+16%乙腈溶液为萃取液,考察了用85%磷酸调节萃取液 pH值为2.0、2.2、2.4.、4、2.6、2.8时盐酸异丙嗪和磷酸可待因的出峰情况。如图3A所示,萃取液pH为2.4时出峰最高,效果最好,因此选用萃取液 pH为 2.4。 2.3.2进样电压、进水时间及进样时间的选择考察了进进电压为 7、8、9、 10、111 kV时的进样效率。如图3B所示,随着电压增大,进样量增大,但11kV后,电压过大产生了大量的焦耳热,进样效率变低,且过大的电压会损坏毛细管柱,因而选用进样电压为 10 kV。 考察了进水时间为0、50、100、150s时的出峰情况,结果显示进水时间对峰面积无太大影响,但电流会因进水而降低,出峰时间延长,因而选择进样前不引进水柱。 在 10 kV的进样电压下,对进样时间分别为70、80、90、100、110s时两种化合物的出峰情况进行了考察,结果见图3C。峰面积随着进样时间的延长而增大,但峰宽增大、柱效降低,当时间超过110 s时,峰严重展宽,甚至分峰,因而选择进样时间为100s. 图3萃取液 pH值(A)、进样电压(B)与进样时间(C)对峰面积的影响 Fig.3 Effect of pH of extraction buffer(A), injection voltage (B) and injection time(C) on peak area1.promethazine hydrochloride, 2. codeine phosphate; background electrolyte:80 mmol/L SDS+20 mmol/L NaH,PO4 (pH 2.4) +16% acetonitrile 2.4 方法的性能 胶束电动色谱联用选择性耗尽进样后,两物质的检测信号均显著增强(强图4)。在优化条件下,阳离子选择性耗尽进样-胶束电动色谱法的性能参数见表1。经计算,其峰高比胶束扫集增大约1000倍,检出限降低约800倍,且方法重复性较好,因而可用本法测定可非糖浆中的盐酸异丙嗪和磷酸可待因,检出限(S/N=3)三别为0.16、0.12u g/L。 表11胶束电动色谱法和阳离子选择性耗尽进样-胶束电动色谱法比较 Table 1 L inear ranges, regression equations, and LODs of promethazine hydrochlorideand codeine phosphate by sweep EKC and CSEI- sweep MEKC Analyte SweepMEKC CSEI- sweepMEKC L inear range Regression LOD Linear range Regression LOD p/(mgL) equation* p/(mg. L) p/(gL) equation p/(ugL) Promethazine 1.6~26 y=29.568x+50.186 0.20 0.9994 0.50~81.3 y=27278x-240.99 0.16 0.9989 hydiochloride Codeine phosphate 1.3~20 v=60.948x+29.363 0.16 0.99960.78~62.5 y=45 837x-760.31 0.12 0.9988 图4标准品与可非糖浆样品的电泳图 Fig.4 Electropherogram s of standard and samp le of compound codeine pho sphate syrup sample A. standard by sweep MEKC, B. standard by CSEI- sweep MEKC, C. sample by CSEI- sweep MEKC; 1.promethazine hydrochloride,2. codeine phosphate; background electrolyte: 80 mmol/L SDS+20 mmol/LNaH,PO4(pH=2.4) +16% acetonitrile 2.5实际样品分析 将可非糖浆稀释2000倍,在优化实验条件下平行测定5次,电泳图谱如图4C所示。经计算,样品中盐酸异丙嗪、磷酸可待因的质量浓度分别为1.23、1.97 g/L, RSD分别为 3.3%、2.1%,与药品的标示值1.40、2.00 g/L比较吻合。样品回收率实验结果见表2。结果表明,本法可用于可非糖浆中盐酸异丙嗪和磷酸可待因的含量测定。 表2样品中盐酸异丙嗪、磷酸可待因的回收率 Table 2 Recoveries of promethazine hydiochloride and codeine phosphate in real sample Analyte Addedp/(g L) Foundp/(ug. L-1) Recovery R/% Average recovery R /% RSDs./% Promethazine hydrochloride 20.3, 30.4,40.6 21.1,29.3,38.9 104, 96,96 99 4.6 Codeine phosphate 15.6.23.4.31.2 15.9.24.7. 30.8 102.106.99 102 3.4 ( 参考文献: ) ( 吴小芳,林芝,李英华.滥饮联邦止咳露致相关性肾病的 21 护理[J].现代临床护理,2008,7(10):66-67. ) ( 贺帅,张忠义,张守尧.鼻可灵喷雾剂中地塞米松磷酸钠、氧氟沙星及盐酸麻黄碱含量的微乳液相色谱法测定 [J] . 分析测试学报,2008,27(6):654-656. ) ( T3 陈建,利云,张家明,等. H PLC法测定复方降压胶囊中利血平及盐酸异丙嗪含量[J].药物分析杂志,2008, 28(7) : : 1159-1161. ) ( [4 4] 吴红英,徐道华,邱栋樑.高效液相色谱法测定盐酸异丙嗪片中盐酸异丙嗪的含量[J].中南药学,2009, 7 (8):603-605. ) ( T5 张召香,何友昭.在柱双重富集毛细管电泳法测定卷烟样品中的无机阴离子[J].分析化学,2005,33(11): 1531-1534. ) ( 16 林森,楚清脆,田秀慧,等.杜仲及其保健品中生物活性成分的毛细管电泳电化学检测[J].分析测试学报, 2007 , 26(3) : 389-392 ) ( 杨晓云,王立世,莫金垣,等.毛细管电泳安培法同时检测异丙嗪和氯丙嗪[J].分析化学,1999,27(8):991. ) ( 78 杨昌金,梅霓,杨程.荧光分光光度法直接测定盐酸异丙嗪片剂及注射液的含量[J].分析科学学报,1999,10 (15) : 412-414 ) ( 191 蔡卓,赵静,江彩英,等.卡尔曼滤波紫外分光光度法同时测定盐酸异丙嗪和盐酸氯丙嗪[J].广西大学学报, 2009,34(3): 3 40-3 4 6. ) ( [10 ] 薛元英,何云华,封满良,等.流动注射化学发光法测定盐酸异丙嗪 [J].分析化学,1 9 99, 27(4):427-429. ) ( [111 徐溢,陈蓉,吕君江,等.盐酸氯丙嗪和盐酸异丙嗪制剂的芯片电泳柱后化学发光检测 [J].药物分析杂志, 2008, 28(12): 2 044-2047. ) ( 1121 QURNO JP, TERABE S Exceeding 5000-fold concentration of dilute an a lytes in micellar electrokinetic chromatography [J ]. Science, 1998,282(5388):465-468. ) ( 131 ZHU Lingyan , T U Chuanhong, LEEHK O n-line concentration of acidic compounds by micellar electrokinetic chroma- tography[J] . Anal Chem, 2002, 74(22):5820-5 8 25. ) ( [14] SMPSON SL,QURNOJ P, T ERABE S O n-line sample preconcentration in capillary electrophoresis fundamentals and applications[J]. J Chromato g r, 200 8 ,1184(1/2):504-5 4 1. ) ( [15] KMJB, OTSUKA K, TERABE S Anion s e lective e x haustive in j ection-sweep micellar electrokinetic ch r omatography [J]. J Chromatog r A,2001, 9 32(1/2):1 129- 1 37. ) ( ◎ 1994-2010 China Academic Journal Electronic Publishing House. All rights reserved. h ttp://www.cnki.net ) O China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net
关闭还剩2页未读,是否继续阅读?
北京华阳利民仪器有限公司为您提供《可非糖浆中盐酸异丙嗪与磷酸可待因检测方案 》,该方案主要用于化药制剂中限度检查检测,参考标准《暂无》,《可非糖浆中盐酸异丙嗪与磷酸可待因检测方案 》用到的仪器有高效毛细管电泳仪(紫外检测)CL1030、高效毛细管电泳仪(紫外检测)CL1020。
