雾沫中雾化形成在静电旋转钟镀膜中的应用检测方案(激光粒度仪)
检测样品
其他
检测项目
雾化形成在静电旋转钟镀膜中的应用
关联设备
共3种
下载方案
Electrostatic, rotating bell (ESRB) application is one of the most important coating application techniques
for industries with demanding specifications for optical attractiveness of coatings, such as automotive. The
ESRB process involves production of droplets using a high-speed rotating bell, which are subsequently
transported to the substrate being coated via shaping air [1-3]. An electrical potential is applied between the
bell and the substrate which further helps droplet atomization and transport. This research investigates the
effects of inertia, centrifugal force, drag force, and electrostatic force on the atomization mechanism and
particle size distribution using an automotive OEM base coat formulation. Coating flow rate (CFR), shaping
air flow rate (SAFR), bell speed (BS), and electrostatic potential (EP) were used as primary parameters to
create various atomization conditions and particle size distributions. The atomization mechanism, ligament
formation, and particle size distribution were measured using high-speed laser shadowography and image
processing. The effects of governing forces and particle size generated on efficiency of droplet transfer to the
substrate and optical appearance of the coatings were studied to generate operating windows for optimum
process efficiency and appearance.
北京欧兰科技发展有限公司为您提供《雾沫中雾化形成在静电旋转钟镀膜中的应用检测方案(激光粒度仪)》,该方案主要用于其他中雾化形成在静电旋转钟镀膜中的应用检测,参考标准《暂无》,《雾沫中雾化形成在静电旋转钟镀膜中的应用检测方案(激光粒度仪)》用到的仪器有LaVision ParticleMaster-Shadow 粒径测量系统、Ekspla CARS 相干反斯托克斯拉曼显微光谱仪、Ekspla SFG 表面和频光谱分析系统。
我要纠错
