燃烧中甲醛的激光诱导荧光检测方案(尾气检测)
检测样品
空气
检测项目
有机污染物
关联设备
共1种
下载方案
Formaldehyde (CH2O) is an important intermediate species in combustion processes and it can through laserinduced
fluorescence measurements be used for instantaneous flame front detection. The present study has focussed on the use of the third harmonic of a Nd:YAG laser at 355 nm as excitation wavelength for formaldehyde, and different dimethyl ether (C2H6O) flames were used as sources of formaldehyde in the experiments. The investigations included studies of the overlap between the laser profile and the absorption lines of formaldehyde, saturation effects and the
potential occurrence of laser-induced photochemistry. The technique was applied for detection of formaldehyde in an internal combustion engine operated both as a spark ignition engine and as a homogenous charge compression ignition engine.
北京欧兰科技发展有限公司为您提供《燃烧中甲醛的激光诱导荧光检测方案(尾气检测)》,该方案主要用于空气中有机污染物检测,参考标准《暂无》,《燃烧中甲醛的激光诱导荧光检测方案(尾气检测)》用到的仪器有汽车发动机多参量测试系统。
我要纠错
