异黄酮 Isoflavones HPLC Conditions ba059 Column : CAPCELL PAK C MG S5 :2.0 mm i.d. x 250 mm Mobile phase : 100 mmol/L KH:PO. (adjusted at pH 4 with H:PO.)/ CH:CN= 70 / 30Flow rate :200 pL/min Temperature : 40℃ Detection : PDA 254 nmInj. vol. :1 pLSample dssohed in : Both compounds were separately dissolved in methanol at 1 mg/mL. 5 pL of each solution was added together. The mobile phasewas added to the mixture to make the total volume 1 mL ※1 pg/mL=1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《大豆黄酮中主要成分分析检测方案(液相色谱柱)》,该方案主要用于豆制品中营养成分检测,参考标准《暂无》,《大豆黄酮中主要成分分析检测方案(液相色谱柱)》用到的仪器有null。
