HPLC Conditions ba060 Column :CAPCELL PAK Ca MGII S5 :4.6 mm i.d.x 250 mm Mobile phase : CH:0H Flow rate : 1.0 mL/min Temperature : 40℃ Detection : RI Inj. vol. : 20 pL Pretreatment : The standard compounds were dissolved in chloroform at 10 mg/ mL, and diluted to 1 pg/mL with methanol. Soymilk was diluted5-fold with methanol, and then shaked for 30 seconds. After thesolution was centrifuged (1500 rpm) for 30 seconds, the upperlayer was filtered with a 0.2-pm filter and introduced to HPLC※1 pg/mL=1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《大豆卵磷脂中主要成分分析检测方案(液相色谱柱)》,该方案主要用于豆制品中营养成分检测,参考标准《暂无》,《大豆卵磷脂中主要成分分析检测方案(液相色谱柱)》用到的仪器有null。
