FHPLC Conditions ma004 Column :CAPCELL PAK C: DD S5: 4.6 mm i.d.x 150 mm Mobile phase: A) 1 mol/L Phosphate buffer (KH:PO: K:HPO-1: 1 in molarratio)/H:0 /CHsCN=12.5/687.5/ 150 B) 1 mol/L Phosphate buffer (KH:PO: K:HPO.=1 : 1 in molarratio)/H:O /CHCN=12.5/ 237.5/ 600 B 20 % (0.0 min)> 80 % (30.0 min)->20 % (31.0 min)->20 %(41.0 min) Gradient Flow rate : 1.0 mL/min Temperature:50℃ Detection : UV 210nm Inj. vol. :5pL Sample dssched in: Erythromycin (4.0 mg) was dissolved in methanol (2.5 mL). and then,mobile phase A (7.5 mL) was added to the solution ※1 pg/mL-1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《肯定列表中红霉素的分析检测方案(液相色谱柱)》,该方案主要用于化药制剂中含量测定检测,参考标准《暂无》,《肯定列表中红霉素的分析检测方案(液相色谱柱)》用到的仪器有null。
