発行日:2013年7月HIEIDO発行人:株式会社資生堂77世(I)事業部 布地纳德是 种副肾皮质激素,被用做支气管哮喘的治疗。使用 CAPCELL CORE C18S2.7 (2.1 mm i.d. x 100 mm), 按照 EP 方法进行分析。色谱柱内径与柱长和 EP 方法所规定的不同,但是分析时间得到明显缩短,而且也达到了EP 所规定的分离度(1.5以上)。 Budesonide is one of the adrenocortical hormones, and is used to treat bronchial asthma.According to European Pharmacopoeia, an isocratic elution was performed with CAPCELLCORE C18 S2.7 (2.1 mm i.d. x100 mm).While inner diameter and length of column werealtered from those described in the method, the required resolution value (1.5 and greater)was passed under largely reduced time of analysis. 布地纳德(10 ug/mL)Budesonide (M.W.430.5) CH, 0 【HPLC Conditions】 Column : CAPCELL CORE C18 S2.7; 2.1 mm i.d. x 100 mmMobile phase : H2O (adjusted at pH 3.2 with phosphoric acid) /CH3CN / ethanol=68/32/2Flow rate : 200 uL/minTemperature :50℃Detection : UV 240 nmInj.vol. :2pLSample dissolved in : H2O (adjusted at pH 3.2 with phosphoric acid)/CH3CN=3/7(10 ug/mL as budesonide)
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《布地纳德中CORE柱快速分析检测方案(液相色谱柱)》,该方案主要用于原料药中含量测定检测,参考标准《暂无》,《布地纳德中CORE柱快速分析检测方案(液相色谱柱)》用到的仪器有null。
