HPLC DATASHEET 匕才夕夕少少墟酸墟Pioglitazone hydrochloride U100927A A) Assay:Sample solution*(0.05 mg/mL Pioglitazone HCI, 0.013 mg/mL Benzophenone] 5 H ·HCI Pioglitazone hydrochloride B) Related substances/Organic impurities: Sample solution*(0.2 mg/mL Pioglitazone HCI) 2 0 Benzophenone *Sample solutions were prepared from Pioglitazone HCI supplied as a reagent for laboratory use. Column : YMC-Triart C18 (5 um, 12 nm) 150X4.6mml.D. Eluent : acetonitrile/100mM CH3COONHa/acetic acid (25/25/1) Flow rate :0.8 mL/min Temperature :25℃ Detection : UV at 269 nm Injection :A)20 uL B) 40 pL- (The Japanese Pharmacopoeia 15th 2nd supplement, The United States Pharmacopoeia 34th) 色谱条件见谱图
关闭产品配置单
深圳凯米斯科技有限公司为您提供《盐酸吡格列酮中含量/有关物质检测方案(液相色谱柱)》,该方案主要用于原料药中含量测定检测,参考标准《暂无》,《盐酸吡格列酮中含量/有关物质检测方案(液相色谱柱)》用到的仪器有null。
