dCole-ParmerPREMIUMSYRINGE PUMPS Cole-Parmer@ Syringe Pumps PRECISION TECHNOLOGYFROM A NAME YOU TRUST PCole-Parmer Ca WHAT SETS COLE-PARMER-BRAND SYRINGE PUMPS APART? They make work easy— ·Preprogrammed syringe library provides automated settingsfor most popular brands of syringes ·Remote control interface allows convenient,hands-free operation ·Networkable up to 99 pumps They maximize the precision and efficiency of your work一 ·High-precision fluid delivery means maximum reproducibility ·Microprocessor control provides extremely smooth, low-pulse flow,from 1 nL/hr to 2451 mL/hr They are among the best-made instruments in the industry- ·Fully welded seams prevent ingress of liquids ·CE approval available throughout the product family INFUSION PUMPS Ideal when accurate, precise amounts of fluids are required anilton ul ·Set up in three simple steps: ·Dispense preset volumeswith automatic shutoff 1.Select syringe brand and type Select brand/type of syringe INFUSION/WITHDRAWAL PUMPS Multipurpose instruments for the programmed infusionor withdrawal of solution ·Automated performance enables unattended fillingof syringes at very low flow rates ·Power Failure indication provides long-termtesting confidence PUSH-PULL PUMPS Opposing syringes operating off the same drive allowsimultaneous infusion and withdrawal Linear encoder eliminates motor overdrive ·Program using easy-to-operate keypad SPECIALTY PUMPS In the U.S. 625 E. Bunker Court Vernon Hills, IL 60061Call toll-free 800-323-4340Phone: 847-549-7600 Fax:847-247-2929 PERFORMANCE SPECIFICATIONS ·±<1% accuracy ·±0.1% reproducibility Programmable models let you program the pump to controlfrom seconds to days, change flow rates, pause, ramp ratesup or down, control outputs, and respond to external TTLsignals-all from the keypad. Standard models 115 VAC ML-74900-00 ML-74900-50 ML-74900-10 ML-74900-30 ML-74900-70 ML-74903-00 230 VAC (CE) ML-74900-05 ML-74900-55 ML-74900-15 ML-74900-35 ML-74900-75 ML-74903-06 Programmable models 115 VAC — ML-74900-60 ML-74900-80 ML-74901-20 ML-74903-10 230 VAC (CE) ML-74900-65 ML-74900-85 ML-74901-25 ML-74903-16 Syringe capacity(number) 10 pL to 60 mL (one) 10 pL to 10 mL (two) 10 pL to 140 mL (two) 10 pL to 10 mL (ten), 20 mL to 60 mL (six),or 100 mL to 140 mL (four) 10 pL to 10 mL (four) 10 uL to 140 mL (one) Min flow rate 10-pL syringe 0.1pL/hr 0.001 pL/hr 0.001 pL/hr 0.001 pL/hr 0.001 pL/hr 0.001 pL/hr 10-mLsyringe 127 mL/hr 0.351 mL/min 21 mL/min 21 mL/min 21 mL/min 21 mL/min Max flow rate 60-mL syringe 519 mL/hr 86 mL/min 83 mL/min 140-mL syringe 145 mL/min 146 mL/min Linear force 20 lb (9kg) 40 lb (18 kg) 40 lb (18kg) 40 lb (18 kg) 40 lb (18 kg) >100 lb (45kg) Advance per microstep 0.529 micron(V2step) 0.088 micron(2 step) 0.165 micron(6step) 0.165 micron(Vi6 step) 0.165 micron(V6 step) 0.165 micron(V16 step) Max step rate 400 / sec 400 /sec 1600 / sec 1600 / sec 1600 / sec 1600/ sec Min step rate V30 sec 3o sec Voo sec Voo sec oo sec 1 pstep/ 120 sec Infusion/withdrawal syringe pumps Standard models 115 VAC ML-74900-20 ML-74900-40 ML-74902-00 230 VAC (CE) ML-74900-25 ML-74900-45 ML-74902-06 Programmable models 115 VAC ML-74901-00 ML-74901-10 230 VAC (CE) ML-74901-05 ML-74901-15 Syringe capacity(number) 10 uL to 140 mL (two) 10 pL to 10 mL (ten), 1 pL to 100 pL (one) 20 mL to 60 mL (six), or 100 mL to 140 mL (four) Min flow rate 10-pL syringe 0.001 pL/hr 0.001 pL/hr 0.001 mL/min 100-uL syringe 127 pL/min Max flow rate 10-mL syringe 21 mL/min 21 mL/min — 60-mL syringe 86 mL/min 一 140-mL syringe 145 mL/min — Linear force 40 lb (18 kg) 40 lb (18 kg) 2.0lb(0.9kg) Advance per microstep 0.165 micron(/16 step) 0.165 micron(/16 step) 1.58 micron(2 step) Max step rate 1600/ sec 1600 / sec 916/sec Min step rate ioo sec Voo sec l4 sec Continuous syringe pumps Standard models 115 VAC ML-74901-50 230 VAC (CE) ML-74901-55 Programmable models 115 VAC ML-74901-60 230 VAC (CE) ML-74901-65 Syringe capacity(number) 10 pL to 60 mL (four) Min flow rate 10-uLsyringe 0.001 pL/hr Max flow rate 10-mLsyringe 21 mL/min 40-mL syringe 86 mL/min Linear force 40 lb (18 kg) Advance per microstep 0.165 micron(6 step) Max step rate 1600 /sec Min step rate oo sec Cole-Parmer注射泵是世界上市场占有率相当高的注射泵之一,其型号齐全、流速范围大,产品线齐全,深受用户的好评!
关闭还剩2页未读,是否继续阅读?
奥然科技有限公司为您提供《电纺丝、微流控中电纺丝、微流控检测方案(蠕动泵)》,该方案主要用于电纺丝、微流控中电纺丝、微流控检测,参考标准《暂无》,《电纺丝、微流控中电纺丝、微流控检测方案(蠕动泵)》用到的仪器有美国KD scientific KDS Legacy注射泵、美国KD scientific KDS Legato注射泵。
