15th Australasian Fluid Mechanics ConferenceThe University of Sydney, Sydney, Australia13-17 December 2004 Transient Behaviour of the Fuel Spray from an Air-Assisted,Direct Fuel Injector S.H. Jin1, M.J. Brear', G. Zakis', H.C. Watson and C. Zavier 'Department of Mechanical and Manufacturing Engineering University of Melbourne, VIC, 3010 AUSTRALIA Orbital Engine Company (Australia) Pty. Ltd. Balcatta, Western Australia, 6021 AUSTRALIA The transient behaviour of the fuel spray from an air-assisted fuelinjector in a constant volume chamber has been investigatedexperimentally. The relative Sauter mean diameter (SMD) of thespray droplets was determined using planar laser inducedfluorescence (PLIF) and planar Mie scattering. Planar images ofthe ensemble averaged relative SMD with various injectionconditions were obtained by calculating the ratio between the twolaser light intensities at a given point. The penetration length andthe spray shape factor were also obtained. The ensembleaveraged results suggest the existence of vortices that are shedfrom the injector tip, and which entrain the smaller droplets.Results also show that the characteristics of the injector varyweakly with several particular injection parameters, notably thefuel injection pressure and the delay between fuel and airinjection. Introduction In order to meet ever-tightening emissions regulations whilstsimultaneously minimising fuel consumption and CO2 emissions,many efforts have been made recently to improve theperformance of gasoline fuelled spark ignition engines. Suchefforts include the manipulation of in-cylinder flow, optimisationof the electronic control systems, and optimisation of directinjectedsparkkignition(DISI)fuel systemsL[1,2].Theimprovements in fuel economy obtained by using DISI haveprompted an increased adoption of this technology in passengervehicles. Further study of fuel sprays in SI engines aims inparticular to minimise the emissions of hydrocarbons (HC),oxides of nitrogen (NOx) and particulate matter (PM) andimprove efficiency through more complete combustion. Since thefuel injection pressure of a DISI engine is typically lower thanthat ofa diesel engine, larger fuel droplets can exist in thecylinder, and so poor fuel distribution and slow evaporation mayresult. This is particularly the case during cold engine startingand warm-up, when the highest levels of HC emissions over theentire drive-cycle usually occur. For these reasons, air-assisteddirect injectors with improved fuel atomisation are currentlyunder development. The air-assisted direct injection fuel system has many uniquefeatures compared with single fluid systems. The most obviousdifference is the addition of air, which is injected directly into thecombustion chamber with the fuel. The pressure and quantity ofthe air influence the characteristics of spray. The characteristicsof the fuel spray play an important role in mixture preparation,which has an effect on combustion and emissions, so it isimportant to understand the spray characteristics within thecombustion chamber. The droplet diameter of the spray is one of the most importantaspects of spray characteristics. Laser diffraction particle analysis(LDPA) and phase Doppler particle analysis (PDPA)aregenerally used to measure the droplet size, but there aredisadvantages to both methods. LDPA is not suitable for densespray measurement because of multiple diffraction phenomena, and PDPA is used for point measurement, so it needs a great dealof time and effort to obtain the droplet size distribution across thewhole spray. It is therefore worthwhile developing alternativemethods, such as the present, planar imaging technique using alaser sheet, to study the transient spray characteristics [3-5]. This paper presents an experimental study of an air-assisted,direct injection (DISI) system. The technique of ‘laser sheetdrop-sizing’(LSD) is used to examine the transient behaviour ofthe fuel spray. These results are compared to back-illuminatedimages at the same conditions, and the spray-tip penetration andshape factor are also determined. Experimental methods The Sauter mean diameter (SMD) can be determined for liquiddroplets by combining the well established techniques of Miescattering and laser induced fluorescence (LIF). The intensity ofthe fluorescence signal measured by LIF is proportional to theconcentration of the fluorescing molecules. As such, the observedfluorescence originates almost entirely from molecules in theliquid phase. As shown in equation (1), the fluorescence intensityper unit area Iur of the emitted light is ideally proportional to thecube of the particle diameter, assuming negligiblelightabsorption and negligible optical amplification [4]- where I, is the intensity of the incident laser beam, x is thedistance travelled by the incident laser beam, k is an attenuationfactor, D is the droplet diameter, dn is the droplet number densitybetween D and D+dD and C is a constant that depends on theexperimental configuration. In the case of significant absorptionor optical amplification, lur has been observed to vary withparticle diameter to a power varying between 2.4 and 3.1 [4]. Theexact relationship can only established by examining a range ofdroplets of known diameter, and the ideal cubic relationship forthe fluorescence is therefore assumed. According to Lorenz-Mie theory, the intensity of Mie scatteringis a function of droplet diameter, the reflection rate of the droplet,polarization, and the wavelength of the incident beam. In the caseof spherical droplets with a diameter larger than 1um andilluminated with a beam of wavelength 355nm, the intensity isapproximately proportional to the square of droplet diameter [4],and can be expressed as: where C2 is a coefficient determined by the characteristics of thedetecting optical system and sca is related to the angle betweenthe direction of incident laser beam and the detecting direction.Using equations (1) and (2), it is then found that the SMD isproportional to the ratio between the LIF and Mie intensities: where C=C22sca/C; has the units of length and could bedetermined with an appropriate calibration method, such as laserdiffraction particle analysis (LDPA) or phase Doppler particleanalysis (PDPA) [6]. The simultaneous measurement of the LIFand Mie scattering signals also yields a relative SMD of the spraythat is not related to the intensity of the incident laser sheet or theabsorption of the laser sheet. Experimental layout A schematic of the experimental set-up is shown in figure 1. Thelight source used was a Nd:YAG laser (Quantel, TwinsB). Thelaser pulse duration was 5ns and the maximum energy was120mJ at a wavelength of 355nm. A sheet beam was formedusing a set of cylindrical lenses and the optical system wascarefully aligned to minimize unwanted stray light such asreflections from the chamber wall. The fluorescence and Miescattered signals were imaged at a right angle to the laser beamusing an ICCD camera (LaVision, FlowMaster3 with intensifier)with a UV Nikon lens (f/# 4.5) and a gate width of 100ns. A GG-400 Schott glass filter was used for the fluorescence signal and a355nm band-pass filter for Mie scattering. Images of the LIF andMie scattering at a given instant during subsequent injectionevents nsemble averaged. The ensemble averageddistributions obtained using 100 and 1000 ensemble averageswere very similar, so all the results presented in this paper used100 ensemble averages. Figure 1. Schematic of experimental set-up. Standard, unleaded petrol (ULP) with an octane number of 91was used as the fuel during experiments. The LIF spectrum ofthis particular ULP blend is broadband, and ranges from 380nmto 440nm, with a peak at 405nm. Absorption and emission bandsareespectrally well separated, ensuring the absence offluorescence trapping and making possible the separation of theMie scattered and the fluorescence signals. The air-ssisted injection ssystem1c(omprisestwo maincomponents: a fuel metering injector, similar to a port fuelinjector, and an air injector, which delivers a mixture of meteredfuel and air into the combustion chamber (figure 2a). The fuelinjector delivers fuel into a reservoir that is internal to theinjector. The air injector then delivers this (metered) fuel into thecombustion chamber. This system has been reported previouslyto exhibit the favourable quality of small fuel droplet size [7]. Aunique feature of the system is the decoupling of the directinjection event with the fuel-metering event (figure 2c). Thisallows the direct injection event to be tailored to the combustionrequirements, rather than being limited by also needing toperform the fuel metering, as is the case in high-pressure singlefluiid injection1 systems. The air-assistedinjectionsystem,installed in the constant volume chamber, has the capability ofvarying the chamber pressure and uses a nominal injection airpressure of 650kPag and a fuel pressure of either 720 or800kPag. Both fuel and air injection pressures were controlled byadjusting pressure regulators. Table 1 outlines the experimentalconditions of the air-assisted fuel injector. With a fuel injectionduration of 4.1ms at 720kPa fuel pressure and 3.1ms at 800kPa, about 10mg of fuel was injected at a frequency of 1Hz. Injectiontiming, laser triggering and ICCD camera control were controlledby LABVIEW software. The times that are reported in this paperrefer to the time after the trigger pulse was sent to the injectordriver. This means that the first appearance of fuel is somewhatlater due to delays within the injector driver and the mechanicalproperties of the injector. These unavoidable delays are typicallya few hundred microseconds long and will be discussed later inthe paper. The experiments were performed with the chamber atambient temperature and pressure and quiescent gas conditions. Figure 2. The air-assisted direct fuel injection system, showing a)overall configuration, b) the injector tip and c) timing schedule Fuel injection pressure (FIP) 720 & 800kPa gauge Air injection pressure (AIP) 650kPa gauge Fuel pulse width (FPW) 4.1ms & 3.1ms Air pulse width (APW) 3ms Fuel metering gain (FMG) 10mg/pulse Air metering gain (AMG) 8.43mg/pulse Fuel and air injection delay (FAD) -1, 0 and 1ms Ambient pressure 101kPa abs. Table 1. Experimental conditions. Results and Discussion The relative SMD of an air-assisted direct fuel injector has beenmeasured using LIF and Mie scattering. Figure 3 shows ensembleaveraged LIF, Mie scattering and relative SMD images collectedseparately. These images were obtained at 1.8ms after the start ofair injection for 720kPa fuel injection pressure and 650kPa airinjection pressure. Both LIF and Mie scattering images were notcorrected for laser profile variation since the images and theprofiles are divided to produce the relative SMD. The systematiclaser profile features could therefore be cancelled across both thelaser height and thickness of the laser sheet. The LIF imageshows the liquid volume fraction, with most of the fuel mass inthe centre of the spray. The Mie scattering image also has astrong signal in the centre of the spray but is narrower in widthcompared to the LIF image. The relative SMD image possesses a small degree of asymmetry about the injector centreline, and suchbehaviour was seen throughout the present set of experiments(eg. figure 7). Previous experiments showed that similar,asymmetric results were reflected when the injector was rotated180", thus showing that this was due to non-axisymmetry in theexperimental set-up, rather than in the measurement technique. Figure 3. Time-averaged images of LIF signal (left), Miescattering signal (middle) and relative SMD (right). The relative SMD image shows that the edge of the spraycontains larger droplets, whilst there are smaller droplets in thecentre. Near the nozzle tip, the signal is not well defined due tothe presence of fuel ligaments and surface scattering of theincident laser beam. Each of the three images in figure 3 showsthat the spray roughly resembles a downward pointing arrow; theMie scattered result shows this most clearly. This behaviour isthought to be due to the shedding of a vortex ring from theinjector at the start of injection. Such behaviour is common instudies of pulsing, single phase injection. In the present, twophase case, the smaller droplets are presumably entrained moreby the vortex ring, and are wrapped around the ring as ittranslates, leading to this ‘arrowhead’ shape. This behaviour, iftrue, highlights the coupling between the gas and liquid phases inthis injection system, and is very different to that of a liquid-onlyinjector. Further experiments (in particular particle imagevelocimetry) and ongoing numerical simulations will determinewhether this vortex structure actually exists. Figure 4. Comparison of relative SMD for different time intervalbetween fuel and air injection (FAD). Figure 4 shows the effect of fuel air delay (FAD) on theensemble averaged SMD. These images were measured 2.0msafter the start of air injection with a 720kPa fuel injectionpressure and 650kPa air injection pressure. As can be seen in thisfigure, there is a difference in droplet size between locations suchas the centre and periphery of the spray, and the droplet size islarger away from the spray centreline. This is thought to be dueto the larger droplets maintaining their initial trajectory better because of their greater inertia. The smaller droplets are deflectedmore by the air, and so can migrate to the injector centreline. Therelative SMD also increases as the FAD decreases. Reasons forthis trend in FAD are not clear, and are presently being studiedusing numerical simulations. Spray characteristics of interest also include the spray tippenetration length, the spray cone angle and the overall spraySMD. The spray tip penetration length was measured directlyfrom the spray images and obtained by measuring the distancefrom the injector exit (figure 2b) to the lowest intensity Miescattering contour in the axial direction. Figure 5 shows the spraytip penetration length as a function of time for the two differentfuel injection pressures (FIP) and delay between fuel and airinjection (FAD). The effects of varying the FIP and FAD arerelatively small.This is to be expected for positive FAD’s, sincethe fuel and air injection events are then separate, with the fuelbeing dumped into the internal reservoir and then injected by theair into the chamber. The spray penetration is also expected todecrease for negative FAD’s, and figure 5 shows this beginningto occur by FAD=-1ms. Time after start of air injection [ms] Figure 5. Spray tip penetration length for different fuel injectionpressure (FIP) and time interval between fuel and air injection(FAD). The spray shape factor is defined as Figure 6 shows that the spray shape factor decreases rapidly afterthe start of injection at all the conditions studied. As figure 7shows, this is due to the width of the spray remaining relativelycontained as thespray penetrates into thechamber. Thishighlights once again the effect of the air-assist on the spraydevelopment [7]. Figure 7 displays a collection of back-illuminated and relativeSMD spray images for different times after the start of airinjection. The relative SMD results for later times are not showndue to the charge impinging on the chamber walls and filling thechamber. As mentioned earlier, there is a delay between theelectrical triggering of the start and end of injection and themechanical response of the injector. The opening and closingdelays for this injector were approximately 1.0ms and 0.6msrespectively. The back-illumination passes through the entirespray and is therefore a projection of an (ideally) axisymmetricproblem, rather than a planar image such as those shown for therelative SMD. Nonetheless, the penetration of the spray in both cases issisimilar, andthereisssomeiesuggestion of theaforementioned spray ‘arrowhead’in the back-illuminated resultsat 1.8ms. Time after start of air injection [ms] Figure 6. Spray shape factor for different fuel injection pressure(FIP) and time interval between fuel and air injection (FAD). Conclusions The characteristics of the fuel spray from an air-assisted, gasolinedirect fuel injector have been performed using optical techniques.The technique of ‘laser sheet drop-sizing’(LSD),which requiredthe combined use of Mie scattering and laser inducedfluorescence (LIF), allowed determination of the relative Sautermean diameter (SMD) of the fuel spray. Both the Mie and LIFimages were ensemble averaged over separate injection events,thereby permitting study of the transient development of theensemble averaged spray. Several, interesting aspects of the transient spray behaviour werenoted. The previously reported spray containment enabled by theair-assist was observed, with the spray maintaining a narrow width as it penetrated into the chamber. The largest droplets werealso observed to lie away from the spray centreline, which wasconsidered reasonable. Finally, there was also some evidence thata vortex ring was shed from the injector at the start of injection,although further, planned experimental and numerical studies arerequired to confirm this. Acknowledgments This work was supported by the Orbital Engine Company,Holden Limited and the Australian Research Council. Theauthors are particularly grateful for the strong co-operation oftheir industrial partners, as well as the technical support from MrT. Grange and Mr D. Halpin. References [1] Zhao, F.Q., Lai, M.C. & Harrington, D.L., The SprayCharacteristics of Automotive Port Fuel Injection - ACritical Review, SAE Paper 950506,1995. [2] Sampson, M.J. & Heywood, J.B., Analysis of Fuel Behaviourin the Spark-Ignition Engine Start-Up Process, SAE Paper950678,1995. [3] Yeh, C., Kosaka, H. & Kaminoto, T., Fluorescence /Scattering Image Technique for Particle Sizing in UnsteadyDiesel Spray, JSME Trans., B 59,1993,308-313. [4] LeGal, P.,Farrugia, N. & Greenhalgh, D.A., Laser SheetDropsizing of Dense Sprays, Opt. Laser Technol., 31, 1999,75-83. [5] Stojkovic, B.C. & Sick, V., Evolution and Impingement of anAutomotive Fuel Spray Investigated with SimultaneousMie/LIF Techniques, Appl. Phys., B 73, 2001,75-83. 6]Jermy, M.C. & Greenhalgh, D.A., Planar Dropsizing byElastic and Fluorescence Scattering in Sprays Too Dense forPhase Doppler Measurement, Appl. Phys., B 71, 2000,703-710. ( [7] C athcart, G. & Z a vier, C . , Fundamental Cha r acteristics of an Air-Assiste dD irect Injection Combustion n S ystem as Applied t o 4-Stroke Automotive G asoline E ngines, SAEPaper 2000-01-0256, SP-1499,2000. )
关闭还剩2页未读,是否继续阅读?
北京欧兰科技发展有限公司为您提供《燃料,喷嘴,喷射中速度场,浓度场,喷雾几何参量检测方案(流量计)》,该方案主要用于其他中速度场,浓度场,喷雾几何参量检测,参考标准《暂无》,《燃料,喷嘴,喷射中速度场,浓度场,喷雾几何参量检测方案(流量计)》用到的仪器有PLIF平面激光诱导荧光火焰燃烧检测系统、时间分辨平面激光诱导荧光测量系统、时间分辨粒子成像测速系统(TR-PIV)。
