The presence of hidden nut and tree nut allergens in foods can result in serious
health issues, necessitating a method capable of detecting and quantifying them at
trace levels using a single robust assay. To find specific peptide markers that can
be
used to determine the presence or absence of specific nuts in food, proteins unique
to
11 tree nuts (almond, pecan, cashew, walnut, hazelnut, pine nut, brazil nut,
macadamia nut, pine nut, chestnut, and coconut) and peanut were enzymatically
digested and analyzed using accurate
mass Q
TOF LC/MS. Each marker peptide was
selected by establish
ing its presence in raw and roasted nuts, processed and
unprocessed food, abundance (sensitivity), sequence size, and uniqueness to a
specific nut. The National Center for Biotechnology Information (NCBI) nr database
searches were performed to confirm pep
tide identities, and to ensure that the
marker peptides chosen were not present in other nuts or common food ingredients
such as barley, corn, rice, soy, and wheat. Two marker peptides were selected for
each tree nut, and four were selected for peanuts. An
alysis of peptide digests from
grains such as barley, corn, rice, quinoa, soy, and wheat did not present interfer
ences. The peptide markers were tested to determine if they could be used to
screen common foods for the presence of the 11 tree nuts and pea
nut at sub
ppm
levels. Foods containing nuts as listed on the label showed a response for the cor
rect nut. Foods processed using equipment also used to process other tree nuts or
peanuts were in certain cases found to contain these other nuts.
安捷伦科技(中国)有限公司为您提供《坚果及树生坚果中多肽标记物检测方案(液质联用仪)》,该方案主要用于其他食品中过敏原检测,参考标准《暂无》,《坚果及树生坚果中多肽标记物检测方案(液质联用仪)》用到的仪器有null。
