云层中液态水含量,LWC,液滴速度,液滴直径检测方案(干涉仪)
检测样品
其他
检测项目
液态水含量,LWC,液滴速度,液滴直径
关联设备
共3种
下载方案
In 2011, NASA Glenn’s Icing Research Tunnel underwent a major modification to it’s refrigeration plant and heat exchanger. This paper presents the results of the subsequent full cloud calibration. Details of the calibration procedure and results are presented herein. The steps include developing a nozzle transfer map, establishing a uniform cloud, conducting a drop sizing calibration and finally a liquid water content calibration. The goal of the calibration is to develop a uniform cloud, and to build a transfer map from the inputs of air speed, spray bar atomizing air pressure and water pressure to the output of median volumetric droplet diameter and liquid water content.
北京欧兰科技发展有限公司为您提供《云层中液态水含量,LWC,液滴速度,液滴直径检测方案(干涉仪)》,该方案主要用于其他中液态水含量,LWC,液滴速度,液滴直径检测,参考标准《暂无》,《云层中液态水含量,LWC,液滴速度,液滴直径检测方案(干涉仪)》用到的仪器有激光相位多普勒干涉仪LDV,PDI,PDPA,PDA、Artium PDI-FP 双量程可机载飞行探头、激光诱导白炽光(LII)烟气分析仪。
我要纠错
