第22卷 第4期环境监测管理与技术2010年8月 2010年8月莫怡玉等.碱性过硫酸钾氧化-气相分子吸收光谱法测定水中总氮第22 卷 第4 期 碱性过硫酸钾氧化-气相分子吸收光谱法测定水中总氮 莫怡玉,茅丽秋²,吴卓智 (1.湛江市海洋与渔业环境监测站,广东 湛江 524039:2.湛江市港务管理局环境监测站,广东 湛江 524027) 摘 要:采用碱性过硫酸钾氧化-气相分子吸收光谱法测定水中总氮,用螺纹盖盖四氟乙烯消化管代替比色管,称重法校正体积,加大 NaOH 用量,讨论了干扰及消除办法。方法在0 pg~20.0 pg范围内线性良好,检出限为 0.016 mg/L,标准溶液平行行定的 RSD≤1.5%,实际水样加标回收率为99.2%~102%,测量结果的扩展不确定度为3.3% 关键词:总氮;碱性过硫酸钾;气相分子吸收光谱法;水质 中图分类号:0657.3 文献标识码:B 文章编号:1006-2009(2010)04-0047-03 Total Nitrogen Determination in Water by Gas Molecular AbsorptionSpectrometry with Alkaline Potassium Persulfate Oxidation MO Yi-yu', MAO Li-qiu’, WU Zhuo-zhi' (1. Zhanjiang Ocean and Fishery Environmental Monitoring Station, Zhanjiang, Guangdong 524039, China;2. Zhanjiang Port Authority Environmental Monitoring Station,Zhanjiang, Guangdong 524027, China) Abstract: Total nitrogen in water was determined by gas molecular absorption spectrometry with potassiumpersulfate oxidation. The detection used polyfluortetraethylene digestive tubes with whorl cap instead of colorime-ter tubes, volume calibration by weighing method and increased NaOH dosage. The interference and its eliminatemeasurement were discussed. A good linearity was in range from 0 pg to 20. 0 pg. The detection limit was0.016 mg/L. RSD of parallel standard solution was ≤1.5%. Spiked recoveries of samples were between99.2% and 102%. Expanded uncertainty of test results was 3.3%. KLeey words:Total nitrogen; AAlkaline potassium persulfate;; Gas molecular absorptionspectrometry;Water quality 总氮是衡量和评价水体富营养化的重要指指。由于城市污水、工业废水和养殖废水日益增加,江、河、胡、海水域的总氮污染日趋严重。目前测定水中总氮的方法有过硫酸钾氧化-紫一光度法1-31、过硫酸钾氧化-一柱还原法41、过硫酸钾氧化-锌镉还原法5-6]气相分子吸收光谱法等。紫外光度法重复性和准确性较差,计算麻烦;镉柱还原法和锌镉还原法操作繁琐,耗时较长,试剂毒性大;气相分子吸收光谱法操作简便,干扰少。今将水样经碱性过硫酸钾加压消解,含氮化合物全被氧化为硝酸盐氮,再经三氯化钛还原成一氧化氮,采用气相分子吸收光谱法测定总氮,取得了满意结果。 与文献[7]相比,方法改进之处为:①用螺纹 盖聚四氟乙烯消化管代替比色管(或具塞试管),省去了纱布包裹操作,避免管塞冲出、管口爆裂损坏样品,且聚四氟乙烯耐酸碱腐蚀,可避免NaOH 腐蚀比色管玻璃带来的含氮化合物干扰,有利于降低空白;②用称重法校正消解后的体积变化(可能由于蒸气溢出,大多数样品消解后质量变轻,体积减少);③加大 NaOH 用量(2~4倍),使消解液碱碱提高(OH 初始浓度达0.24 mol/L),以便更好地吸收消解时释放的Cl,和H*,改善过硫酸钾对高盐度水样的氧化能力。 ( 收稿日期:2009-11-06;修订日期:2010-04-18 ) ( 作者简介:莫怡玉(1970一),女,广东化州人,工程师,大专,从 事渔业资源与环境保护工作。 ) 1 试验 1.1 主要仪器与试剂 AJ 2100 型气相分子吸收光谱仪,上海安杰环保科技仪器有限公司;镉空心阴极灯;恒温水浴锅;电子天平(精度0.01g);螺纹盖聚四氟乙烯消化管;高压蒸气灭菌锅;微量移液管。 硝酸盐标准溶液:以国家标准物质硝酸盐标液(1000 mg/L)为储备液,用微量移液管吸取2.00 mL 稀释至100mL,得 20.0 mg/L-N标准使用液;50 g/L过硫酸钾溶液:称取10g过硫酸钾(K,S,0g,AR),溶于200 mL 水中;400 g/L NaOH溶液:在塑塑烧杯中加水溶解40 g NaOH(AR),冷却后稀释至100mL(预先标记好),保存于聚乙烯瓶中;6 mol/L盐酸溶液:于250mL水中加入250 mL浓盐酸(GR);三氯化钛(CP,15%),商品试剂,直接使用;干燥剂为无水高氯酸镁(AR,20目);颗粒状无水氯化钙(AR,16目);试验用水为电导率≤0.5 p.S/cm 的去离子水或其他等效纯水。 1.2 试验方法 1.2.1 校准曲线 吸取硝酸盐氮标准使用液0 mL、0.20mL、0.40 mL、0.60 mL、0.80 mL、1.00 mL于反应瓶中,加水至5.0 mL,各瓶含氮质量分别为0 ug、4.00 pg、8.00pg、12.0 pg、16.0 ug、20.0pg。 向各瓶中加入3.0 mL 6 mol/L 盐酸溶液,置于(70±2)℃恒温水浴中加热20 min 后取出,立即接入管路,加0.5 mL 三氯化钛,计时30 s,于214.4 nm 波长处测量吸光值。 1.2.2 样品测定 ①吸取20 mL 样品于 50 mL螺纹盖聚四氟乙烯消化管中,取样时仔细摇匀,若样品含氮较高,可适当减少取样体积,加水至20mL;②加入4mL50 g/L 过硫酸钾溶液和0.6 mL 400 g/L NaOH溶液,加水至25mL,盖紧,称其质量(精确至0.01g),置于高压蒸气灭菌锅中加热,控制压力为1.1 kPa~1. 4 kPa,30 min 后切断电源;③自然冷却至压力为0,取出放冷,称其质量,并加水至原来质量;④吸取5.0 mL(可少取,加水至5.0mL)于反应瓶中,与校准曲线同样方法测量吸光值。 1.2.3 空白测定 与样品同样方法消解、测定1个或多个纯水空白样。 2 结果与讨论 2.1 校准曲线 校准曲线的测定结果见表1。 表1 校准曲线 Table 1 Standard curve 标准点m/pg 0 4.00 8.00 12.0 16.0 20.0 A 0.0004 0.037 9 0.0776 0.11720.1589 0.197 8 A-A 0 0.0375 0.077 2 0.1168 0.158 5 0.1974 回归方程 y=0. 009 93x-0.0014 相关系数r 0.999 9 2.2 方法检出限 平行测定6个空白样(经消解),吸光值分别为0.002 3、0.0025、0.0023、0.002 5、0.0018、0.0022,标准偏差为0.00026,根据 DL=3s/K 计算方法检出限为0.016 mg/L。 2.3 精密度试验 用该方法对两个标准溶液平行测定4次,结果见表2。 表2 精密度试验结果 Table 2 Test results of precision 标准 测定值p/(mg·L-) 均值 RSD 溶液 2 3 4 p/(mg·L) /% A 1.21 1.20 1.23 1.23 1.22 1.5 B 1.26 1.27 1.29 1.28 1.28 1.4 2.4 样品测定与加标回收试验 用该方法测定水和海水样品,并做加标回收试验,结果见表3。 表3 样品测定与加标回收试验结果 Table 3 Test results of samples and spiked recoveries 水样 测定值p 加标量p加标后测定值 回收量p回收率 /(mg·L-)/(mg·L)p/(mg·L)/(mgL") /% 自来水 0,058 0.800 0.853 0.795 99.4 鉴江河水 0.767 0.800 1.57 0.803 100 港口海水 0.336 0.800 1.13 0.794 99.2 混合海水 0.151 0.800 0.971 0.820 102 2.5 干扰及消除 试验表明,消化管的材质对测定结果有较大影响。由于消化温度较高,消化液的碱度也较强,玻璃中的含氮物质会水解出来18],使空白值增加,精 密度变差,故不宜选用玻璃消化管。塑料大多不耐高温,部分塑料还不耐碱腐蚀。试验使用半透明的“聚丙烯”消化管,所得消化液中有很多白色片状的小漂浮物,测定结果极不稳定,疑为“聚丙烯”中加入了其他塑料(如聚酰胺)。聚四氟乙烯管是最佳选择,应注意选择纯白色有光泽的产品,避免使用纯度不高的材质。 消解液中如含有大量高价金属离子(如Fe),则会消耗过多的还原剂而影响测定,此时加大三氯化钛用量,保持红色不褪即可消除干扰。 2.6 测量不确定度的评定 参照文献[9]与《化学分析中不确定度的评估指南》(CNAS-GL06:2006),评定改进后方法的测量不确定度。其主要影响因素有:①有证标准物质具有的不确定度;②移液器、容量瓶等玻璃仪器容积误差引人的不确定度;③称量误差;④重复性测定操作引入的不确定度;⑤校准曲线拟合引入的不确定度。经计算,测量结果的扩展不确定度为3.3%。 3 结语 采用改进后的碱性过硫酸钾氧化-气相分子吸收光谱法测定水中总氮,方法灵敏度较高,重复 (上接第14页) 行有针对性的突破必然是连续监测技术发展的方向。 随着节能减排工作的不断推进,伴随着法律法规要求烟气连续监测污染因子的增多,原来适用于低湿、高硫的直接抽取冷干法不再适合目前高湿、低硫的工况,取样方式有向直接测量式发展的趋势,进而向遥测方式发展;分析技术则以光学技术为主导,向全谱分析和线状光谱技术方向发展;测量范围逐渐向低浓度发展,追求更高的准确度和咪密度。 另外,低碳时代的到来,温室气体的排放被普遍关注,烟气中 CO,的实时准确监控不可避免地被提到议事日程。以前 CO,气体浓度大多通过计算得到,其准确性不容乐观,因而直接测量 CO,的监测分析技术将得到迅速推动。H,S、HC、HF、Hg等有毒有害物质的在线监控,也将成为环保部门关 性和准确度良好,适用于海水、地面水、养殖水及人海排放口的水质监测。 ( [参考文献] ) ( [1] 国家标准化管理委员会.GB 11894-89 水质 总氮的测定碱性过硫酸钾消解紫外分光光度法[S].北京:中国标准出 版社,1989. ) ( [2] 国家环境保护总局《水和废水监测分析方法》编委会.水和废水监测分析方法[M].4版.北京:中国环境科学出版社, 2002:254. ) ( [3] 陈杰,吴亦红.碱性过硫酸钾氧化化定城市污泥中总[J]. 环境监测管理与技术,2005,17(1):35-36. ) ( [4] 国家海洋局.海水增养殖区监测技术规程 附录B(规范性 附录) 水 中总氮测定一碱性过硫酸钾氧化法[S].北京:中国标准出版社,2002. ) ( [5] 国家海洋局.GB 11378.4 海洋调查规范(第4分册) 总氮测定(锌镉还原法)[S].北京:中国标准出版社,2007:26. ) ( [6] 中华人民共和国国家质量监督检验检疫总局,中国国家标准 化管理委员会.GB 17378.4-2007 海洋监测规范 第4部 分:海水分析[s].北京:中国标准出版社,2007:121. ) ( [7] 国家环境保护总局.HJ/T 199-2005 水质 总氮的测定气相分子吸收光谱法[S].北京:中国环境科学出版社,2006. ) ( [8] 吴卓智,莫怡玉.塑料管中氧化-气相分子吸收光谱法测定 水中氨氮[J].环境监测管理与技术,2008,20(2):38-40. ) ( [91 中国金属学会. CSM 01010102-2006 分光光度法测量结果 不确定度评定规范[S].北京:中国标准出版社,2006. ) ............................................................................................................................................................................................................................................................................................................................................... 注的焦点。 ( [参考文献] ) ( [1] 朱法华,王飞,潘荔,等.全国火电厂烟气连续监测系统运行 状况调研及分析[J].中国环境监测,2000,16(5):7-11. ) ( [2] 易江.连续排放监测系统(一、发展进程)[J].现代科学仪 器,2000(1):47-49. ) ( [3] 李宁.基于差分光学吸收光谱技术的空气质量连续监测系统 研究[D].天津:天津大学,2005. ) ( [4] 郑海明.固定污染源烟气中汞排放连续监测系统[J].环境监 测管理与技术,2009,21(1):8-12. ) ( [5 杨凯,滕恩江.烟气连续监测系统的相对准确度度测[J].环 境监测管理与技术,2005,17(4):31-34. ) ( [6] 齐宏景,何青,王秉仁.火电厂烟气排放连续监测系统的设计 [J].电力情报,2001(4):56-58. ) ( [7] 谭衢霖,邵芸.遥感技术在环境污染监测中的应用[J].遥感 技术与应用,2000,15(4):246-251. ) ( [8] 李晶,孟祥亮,张玉梅.山东省生态环境遥感监测及其动态变 化研究[J].环境监测管理与技术,2009,21(3):71-74. ) 采用碱性过硫酸钾氧化-气相分子吸收光谱法测定水中总氮,用螺纹盖聚四氟乙烯消化管代替比色管,称重法校正体积,加大氢氧化钠用量,讨论了干扰和消除办法。方法在0μg-20μg范围内线性良好,检出限为0.016mg/L,标准溶液平行测定的RSD≤1.5%,实际水样加标回收率为99.2%-102%,测量结果的扩展不确定度为3.3%。
关闭还剩1页未读,是否继续阅读?
上海安杰智创科技股份有限公司为您提供《海水中总氮检测方案(气相分子吸收)》,该方案主要用于环境水(除海水)中营养盐检测,参考标准《暂无》,《海水中总氮检测方案(气相分子吸收)》用到的仪器有气相分子吸收光谱仪 AJ-3000 Plus。
