检测样品 畜禽肉及副产品
检测项目 兽药残留
参考标准 GB/T 21981动物源食品中激素多残留检测方法 液相色谱-质谱/质谱法
银牌会员 474 篇解决方案
北京豫维科技有限公司联系人:水先生电话:18911849923中国卫生检验杂志2016年11月第26卷第21 期 Chin J Health Lab Tec, Nov. 2016, Vol. 26, No. 21·3089· 高效薄层条带快速净化检测猪肉中瘦肉精的残留 滕卫林',陈咪佳,吴俊,张宜明 1. 杭州市疾病预防控制中心,浙江杭州310021;2.浙江农林大学,浙江临安311300;3. 临安市疾病预防控制中心,浙江临安311300 摘要:目的 本实验利用薄层净化与气质联用仪相结合技术,建立了快速检测动物组织中残留瘦肉精的方法。方法 通过优化薄层展开程序,获得瘦肉精在自制的纸基薄层板上稳定的比移值(Rf)。样品经过提取、浓缩后,在纸基薄层板上进行净化,通过裁切目标区,以甲醇洗脱,洗脱液经衍生剂反应后,用气质联用仪,在 SIM 模式下检测定量。结果 在优化条件方法下,样品中的杂质得到完全分离。在浓度范围为0.02 pg/ml~0.5 pg/ml时,线性关系良好,线性回归方程为y=358 971x+18 441,r=0.9992;加标回收率为71.3%~84.7%(外标法),最低检出限为2.0 pg/kg(基于3倍信噪比)。结论 本方法操作快速方便、灵敏准确,能满足猪肉样品中瘦肉精的快速分析要求。不仅节约了前处理时间,更有效地降低了溶剂消耗,表现出环境友好等特点。纸基薄层色谱条带有望在农产品样品前处理领域获得良好应用。 关键词:薄层色谱;瘦肉精;净化;气相色谱-质谱 中图分类类:0657 文献标识码: A 文章编号:1004-8685(2016)21-3089-04 Rapid detection of clenbuterol residues in pork with high performancethin layer clean -up technique TENG Wei -lin",CHEN Mi -jia, WU Jun, ZHANG Yi -ming Hangzhou Municipal Center for Disease Control and Prevention, Hangzhou, Zhejiang 310021, China Abstract: ObjectiveTo establish a method to rapidly detect clenbuterol residues in pork tissues with high performance thinlayer clean - up technology and gas chromatography mass spectrometry ( GC-MS). Methods Throughout optimization of sol-vent development procedures, the stable Rf value has been obtained on the surface of paper -based thin layer chromatographyslides. The sample was extracted and concentrated for purification on paper - based thin layer. Consequently, the target zonewas cut with methanol for elution, and the elution solution, after derivation, was detected by GC- MS instrument under SIMmode. Results In this optimized method, the impurities in the sample were completely separated. And when the concentra-tions were within 0.02 pg/ml-0.5pg/ml, good linearity was obtained; linear regression equation was y=358 971x+18441,r=0. 999 2, with the recovery rates within 71.3% -84.7%, and the minimum detection limit as 2.0 pg/kg. Conclu-sion The method is fast and convenient, sensitive and accurate, and can meet the requirement of rapid analysis of clenbuterolin pork samples. The method not only saves the pre -treatment time, but also more effectively reduces the solvent consumption,showing the characteristics of environmental friendliness. Thus, current constructed paper - based thin layer chromatographyslides is expected to be applied in the sample pretreatment field of agricultural product. Key Words: Thin layer chromatography; Clenbuterol; Clean -up; Gas chromatography mass spectrometry 瘦肉精是一类能促进瘦肉生长、抑制肥肉生长的化学物质,在我国瘦肉精一般指克伦特罗(Clen-buterol) ,其正式名为盐酸克伦特罗,化学名称为α-[(叔丁氨基)甲基]-4-氨基-3,5-二氧苯甲醇盐酸盐,简简克伦特罗,又名克喘素、氨氨哮、氨必妥、氨双氯喘通,为白色结晶状粉末,味略苦。 目前,普遍的净化方法是固相萃取柱法,该方法 ( 基金项目: 浙江省 医药 卫生 一 般研究计划(20 1 3 KYA171) ) ( 作者简介:滕卫林(1976 -),男 ,硕 士 , 副主 任 检 验技 师 , 主 要 从 事 理 化检 验工作。 ) 的经济成本较高,对样品的预处理过程较为繁琐且溶剂消耗量较大,耗时较长2-31。检测平台有气相色谱-质谱联用或者液相色谱-质谱联用方法4-,综合而言,样品的前处理非常耗时费力,难以及时应对突发性食物中毒的快速分析。已有报道薄层层析可用于猪肝中的瘦肉精分析,但其分析的灵敏度不能满足有关要求。鉴于此,本实验采用薄层净化方法实现了样品的快速净化,简化了实验过程,不仅可以在同一块薄层板上进行多样品的同时点样,而且可以以条带点样方式加大上样量,简便省时。猪肉样品经粉碎、提取、浓缩、争化、洗脱、衍生等处理后,可以迅速得到满足气相色谱-质谱法(GC-MS)检测的最终样 品。通过薄层板净化与未经薄层板净化的样品质谱图对比,分析薄层板的净化效果是否满足对样品检测的需求。 材料与方法 1.1 样品 猪肉样品于4月上旬采购于临安浙皖农贸城,经粉碎后,保存于-20℃冰箱中。 1.2 仪器与试剂 气质联用仪(GC -MS -PO2010,岛津制作所,日本);电子天平(BS-210S,深圳深美仪器有限公司,中国);旋转蒸发仪(IKA RV10,IKA -Werk 仪器设备有限公司,德国);高速冷冻离心机(Thermo X1R,赛默飞科学仪器有限公司,美国);氮吹仪(N-EVAPTM 111, Organomation 实验辅助设备公司,美国);小型离心机(IKA miniG,IKA - Werk 仪器设备有限公司,德国);涡旋混匀机(IKA MS3,IKA-Werk 仪器设备有限公司,德国);SP-H型电动点样器(上海科哲生化有限公司);进样瓶若干。甲醇、乙酸乙酯、乙酸、甲苯、衍生剂:N,O-双三甲基硅烷三氟乙酰胺( BSTFA)、克伦特罗标准品(1.0 mg/ml)。将自制纸基硅胶Go薄层板裁切为长5 cm,宽2.2 cm。上、下各距边缘0.5 cm画线标记点样区和溶剂前缘区,因此展距为4cm。 1.3 方法 1.3.1 仪器条件 1.3.1.1 色谱条件 色谱柱 Rxi -5 ms 毛细管柱(30 mx0.25 mm,0.25 pm);优化后的色谱条件,升温程序:初温120℃,保持3 min,然后以 10℃/min 升至230℃,保持5 min,再以 10 ℃/min 升至280℃保持5 min。载气:氦气,纯度为99.999%,恒压模式;进样量:1.0 p.l;进样方式:不分流进样。 1.3.1.2 质谱条件 离子源温度为230℃;辅助接口温度为250℃;溶剂延迟10 min;扫描方式:选择性离子的 m/z 是选择离子监测方式;选择离子为86、243、262,其中定量离子为86。优化条件下浓度为0.1 pg/ml瘦肉精经衍生后标准的选择离子流图(图1)。 图1 0. 1 pg/ml瘦肉准标准选择粒子流图 1.3.2 薄层板预处理与展开瓶 展开剂配制:展开剂配比为乙酸乙酯:甲醇:乙酸=8:1:0.8。展开瓶:在磨口广口瓶瓶底铺上一层海砂,海砂上放置一张适当大小滤纸片,滤纸片大小以广口瓶瓶口外沿大小为基准。薄层板预处理:薄层板用镊子夹取,使用 前先于展开剂中展开一次。展开结束后,用托盘盛放,在80℃电热鼓风干燥箱中,烘烤30 min,取出备用。 1.3.3 薄层板目标区的定位 点样:精确移取50 p.l克伦特罗标准品(1.0 mg/ml),用点动点样器在0.5 cm画线位置进行条带点样。展开与烘干:在展开瓶中加入适量展开剂,展开剂液面以低于点样位置高度为准。将点样完成的薄层板放入展开瓶中,薄层板应直上直下,避免倾斜,盖上瓶塞,等待展开完成。将已展开完成的薄层板从展开瓶中取出,放置于自动点样器上加热烘干表面残留的展开剂。裁切与洗脱:用镊子夹取已烘干的薄层板,放置于托盘上,以3.2 cm为基准,上下±2 mm,即以4 mm 为间隔,连续裁切下5个条带,分别放置于1.5 ml加塞离心管中,并加入0.5 ml甲醇进行初次洗脱,并做好标记。将初次洗脱液,在60℃下进行氮吹,直至吹干。在离心管中再次加入0.5 ml 甲醇,进行二次洗脱,洗脱后,取出条带,二次洗脱液备用。衍生:在60℃下,将二次洗脱液氮吹至干。将吹干物置于80℃烘箱中,烘烤1 min ~2 min,烘干剩余水分。在离心管中,分别加入100 p.l衍生剂与100 pl甲苯,加塞后于涡旋混合器充分混匀。在80℃烘箱中,恒温衍生60 min, 衍生结束后,取出,氮吹至干,加入甲苯0.5 ml 溶解吹干物,供GC-MS检测110-121。标准品衍生:精确移取适量体积克伦特罗标准品(1.0 mg/ml),逐级稀释后按相同方法与洗脱液进行同步衍生。目标区定位:将克伦特罗标准品与点板洗脱液衍生后的离子质谱图进行对比,确定克伦特罗在该实验条件下,薄层板上展开后的目标区,确定比移值(R)。 1.3.4 样品的提取 空白样品:称取样品5g(精确到0.01 g),置于50 ml 离心管中,加甲醇20 ml,在均质机上,以10 000 r/min 均质60 s,加盖,于-20℃冰箱中冷冻10 min,取出离心管,8000 r/min 离心10 min。移取上清液10 ml于25 ml鸡心瓶中,60℃下旋转蒸发至2 ml~3ml。将上清液转移至洁净10 ml离心管中,在60℃下氮吹至少于0.5 ml,转移至1.5 ml 洁净离心管中,用300 p.l 甲醇清洗 10 ml 离心管内壁2次,合并清洗液至 1.5 ml离心管中,加盖,于-20℃冰箱中冷冻2 min,取出离心管,离心1 min。将上清液转移至洁净1.5 ml 离心管中,在60℃下氮吹,至剩余0.5 ml ~0.8 ml,取下离心管,加盖,于-20℃冰箱中再次冷冻2 min, 取出离心管,离心1 min。将上清液再次转移至洁净1.5 ml 离心管中,在60℃下氮吹,至剩余100 p.l,加入100 p.l 甲醇,充分混匀,备用。加标样品:称取样品5 g(精确到0.01 g),置于50 ml 离心管中,加甲醇20 ml,加不不同体积的克伦特罗标准品(2.0ug/ml),按上述方法同步处理。加标样品的平行设置:按上述加标样品的处理方法,设置3组平行试验,计算其加标回收率。 1.3.5 样品的净化与衍生取上述空白样品与加标样品各100 p.l,分别在薄层板上进行条带点样。点样完成后,在展开瓶中进行展开。展开完成后,根据1.3.3中所确定的比移值,裁切目标区条带2 mm 宽,按照1.3.3洗脱步骤进行洗脱。洗脱液按1.3.3衍生方法进行衍生化,供 GC -MS 检测。标准品衍生:取100 p.l克伦特罗标准品(2.0 pg/ml)与样品洗脱液进行同步衍生,以此为基准,计算加标回收率。1.3.6 标准曲线的绘制 精确移取克伦特罗标准品(2.0 ug/ml)10 p.l 25 pl、50 pl、100 pl、250 pl分别加入1.5 ml离心管中,吹吹至干,按照上述衍生方法进行衍生,得到最终克伦特罗浓度为0.02 pg/ml、0.05 pg/ml、0.1 pg/ml0.2 pg/ml、0.5 pg/ml。经GC - MS 测定,以浓度为x轴、峰面积为y轴,绘制标准曲线。 2 结 果 2.1 薄层板预处理与展开瓶 由于薄层板表面会附着杂质,因此在点样展开前,需要对薄层板进行预展开处理,排除表面杂质,并于80℃烘箱中,烘烤活化30 min。常规展开所使用的展开缸体积较大,需要的展开剂体积大,展开体系内蒸汽不易饱和。本实验所采用的展开瓶体积小,展开所需的展开剂较少,蒸汽易饱和。展开瓶瓶底铺上一层海砂,海砂上覆盖一张圆形滤纸片,使展开瓶瓶底呈现水平状态,能够保证薄层板在展开瓶中以一种平直稳定的状态进行展开。2.2 薄层板目标区的定位 由于本实验所测定的克伦特罗为无色,因此在薄层板上展开后,需确定克伦特罗在乙酸乙酯-甲醇-乙酸体系下的比移值。根据所查文献,在该体系下,克伦特罗的比移值为0.81。由于展距为4 cm,因此克伦特罗迁移距离应为3.2 cm,以3.2 cm 为基准,上下±2mm,即每条条带宽4 mm,进行条带的连续裁切。分别裁切出5条条带,各条带在薄层板上的距离(以4cm展距在基准) 如表1所示。 表1各裁切条带在薄层板所对应的距离(以4cm展距为基准) 条带编号 条带在薄层板上对应的距离(cm) ① 3.4~3.8 ② 3.0~3.4 ③ 2.6~3.0 ④ 2.2~2.6 ⑤ 1.8~2.2 上述条带进行洗脱、衍生、GC-MS检测后得到克伦特罗的质谱图,与克伦特罗标准品直接衍生所得质谱图对比,最终确定克伦特罗在当前所用的纸基薄 层条上展开后,处于⑤号条带,得到比移值为0.5。 由上述结果可知,由于本实验所采用的薄层板为自制纸基硅胶 Go薄层板,所以克伦特罗在乙酸乙酯-甲醇-乙酸展开体系下迁移距离小于文献所述。不同薄层板所带来的比移值差距属于可控、可接受范围,以连续裁切方法进行薄层板目标区的定位是可行的 克伦特罗标准曲线与最低检出限 按上述实验方法,衍生后,供 GC - MS 检测的克伦特罗浓度为0.02 pg/ml、0. 05 pg/ml、0. 1 pg/ml、0. 2 pg/ml、0.5 pg/ml,线性回归方程为y=358 971x+18 441,r=0.9992(图2),最低检出限为2.0 pg/kg。由此可见,克伦特罗在该实验条件下,在浓度范围为0.02 pg/ml~0.5 pg/ml时,线性关系良好。 图2 克伦特罗标准曲线 2.4 加标回收率与精密度 通过上述方法处理后,样品的加标量分别为20 pg/kg 和100 pg/kg,对样品中的克伦特罗检测结果进行计算,得出该方法的加标回收率以及相对标准偏差,如表2所示。该方法下,克伦特罗的加标回收率为71.3%~84.7%,证明以高效薄层净化-气质联用技术检测瘦肉精的方法,取代固相萃取柱净化是可行的。 表2 加标回收率和精密度(n=5) 组分名称 加标水平1 加标水平2 加标量 回收率 RSD 加标量 回收率 RSD (pg/kg) (%) (%) (pg/kg) (%) (%) 瘦肉精 20 77.1 6.1 100 79.5 5.9 20 81.2 100 78.5 20 84.7 100 83.8 20 77.3 100 71.3 20 72.0 100 75.6 2.5 薄层板的净化效果比对 猪肉样品经粉碎、提取、浓缩后,通过薄层板净化、洗脱、衍生,最终得到满足 GC -MS 检测要求的检测样品。通过经薄层板净化与未经薄层板净化的质谱图(图3)对比,得到薄层净化的效果,通过薄层净化后,样品中杂质明显被分离,因此可以得到满足后续检测条件的洁净样品。 注:A:争化;B:未净化。 图3 纸基薄层净化样品与未净化样品质谱总离子流图(TIC)对比 3 结 论 采用薄层条带净化的方法,建立了气相色谱-质谱联用仪检测瘦肉精的方法,尽管采用外标法,但本方法仍能够较保证实验的定量可靠性。在该方法下,样品杂杂得到基本分离,加标回收率为71.4%~72.3%,最低检出限为2 pg/kg。 本方法操作快速方便、灵敏准确,能满足猪肉样品中瘦肉精的快速分析要求。此外,该方法试剂消耗少,操作快速可满足瘦肉精大批量样品的检测要求。 ( 参考文献 ) ( [ 1 ] 吴 宁 鹏 , 班 付国 ,周红 霞,等.浅谈气质联用测 定 盐 酸 克伦特 罗 [J ] . 中国畜牧兽医,2 00 6,33(10 ) : 7 2-7 3. ) (上接第3088页) 3 结 论 本实验用乙腈-水作流动相,建立了 UPLC 测定酸奶中激素残留方法的研究。结果表明,本实验快速、简便、准确、灵敏,不仅能够完全满足日常的酸奶检测,并为进一步研究提供了帮助。 ( 参考文献 ) ( [ 1 ] 中 华人民共和国国家 质 量监督 检验 检疫总局. G B / T21981 - 2008 动 物源食品中激素 多 残留检测方法液相色谱- 质 谱/ 质 谱法[ S ]. 北京: 中 国标准出版社,2008. ) ( 21 中华人民共和国国家质量 监 督检验检疫 总 局. G B / T 22992一 2008 牛奶和奶粉中玉 米 赤赤醇、 玉米 赤赤酮、 己 烯雌酚、已烷雌 酚、 双烯雌酚残留量 的 测定液相色谱- 串 联质谱 法 [ S ] . 北 京: 中国标准出版社,2 0 09. ) ( [ 2 ] 裴 茂 清 , 王 俊 新 ,伍 海 亮.克伦特罗的定性 分 析 方 法[J ] .广东 公安 科技 , 20 0 2(1 ): 17- 18 . ) ( [ 3 ] 戴 镜红, 高伟文, 陈满基 .一 起 盐酸克伦 特 罗 引起 食 物 中毒的 调查与 思考 [J ] . 中 国 动物 检 疫 , 2 0 0 3 ,20(10 ) : 3 . ) ( [ 4 ] 宋永青,郭文萍 , 赵蓉, 等.气 相 色 谱 -质 谱法测定 动物 性 食 品 中 三 种 β- 激 动 剂的残留量[ J]. 肉 类研 究 , 20 0 7(1 1 ) : 45 -4 9. ) ( [ 5 1 黄义 彬 . 猪 肉 中 盐 酸 克伦特罗 和 盐酸 菜 克多 巴胺 残留量 检 测 气质 联用 法 探讨[J] . 农 技服 务 ,2 011 , 28 ( 1) :6 7- 70 . ) ( [ 6 ] 张 雪曼 ,程雪梅,苏青 云.气 相 色 谱 - 质 谱 联用法同时 测定动 物尿液中克 伦 特罗和沙丁胺 少 [J] . 分 析试 验室 ,200 7, 2 6 (2) :89- 9 3. ) ( [ 7 ] 中 华 人 民 共 和国 质 量监督 检 验检疫总 局 . GB/ T22 1 47-2 0 08 饲 料中 沙 丁 胺 醇 、 莱 克多 巴胺 和盐酸克仑特 罗 的测定[S ] .北 京 :中 国国准出版社,2 0 08. ) ( [ 8] 王 旭 峰 , 赵丽,张 高 奎,等 .液 相色 谱- 串联 质谱法同 时 测定 猪尿 中23 种 违禁 药物 [J] .分 析化学 , 2 0 13 ,41 ( 8): 1 254 - 1 2 58. ) ( [ 9 ] 黄 宝 华,尚红霞, 张 兰英.薄层 扫 描法测 定猪 肝中克伦特罗残 留量 [ J ] . 食品 科学, 2 004,25(1 ) : 12 1-123. ) ( 1 01 浙江 省 质量技术监督局. D B33/T624—2 0 06 动物组 织中 特 布 他林 、 克伦特 罗、 沙 丁胺醇 和 莱克 多 巴胺 残留量 的测定气 相色 谱- 质质 法[S ] .浙 江:浙 江标准信 息网 ,2 006. ) ( [ 11 ] Eng e lmann MD , Hinz D, Wenclaw ia k B W . So li d -ph as e m ic r oex-tr a ctio n ( SP ME ) and he a ds p a ce de r iv a t i zation of cle nbuter o lfo l owed b y GC - FID and GC - S I MMS qu a nt ificati o n [J ] . A n alBio a nal Che m, 200 3 , 375 ( 5 ) : 4 60- 46 4. ) ( 1 2 1 陈 剑 刚 , 白艳玲,张彩 红,等. 固相 萃 取 -气 质联用法分 析肉食 品中盐酸克伦特罗残 留 量[J ] . 中国卫生检 验 杂志 , 200 3, 13 ( 6 ) : 7 12- 7 13. ) ( 收稿日 期:2016- 0 6- 2 8 ) ( [ 3 ] 周建 科, 岳 强,宿 书 芳 ,等.牛 奶中雌性激素 的 高效 液 相色谱 的 分析[ J ] .中 国 乳 品 工 业, 20 05,33(8): 5 6-57. ) ( [ 4 ] 迂 君 , 张秀 丽, 张 玉 黔 .高 效液相色 谱 法 测定牛奶 中雌 激 素 残 留量 [ J ] .中 国 卫生 检验杂 志 , 200 7,17(6) : 1 1 39-1 1 40. ) ( [ 5 1 林子俺, 庞纪磊, 黄慧 ,等.水产品中己 烷雌酚 、己 烯雌 酚与双烯 雌酚残留的 毛 细 管 电 泳 测定 [J] . 分析 测试学报,2010,29 (1) : 5 5- 5 8. ) ( 61 朱坚,李 波 ,方晓明: 气 相色谱 -质谱法测定 肝、 肾和 肉 中11 种 β - 受体 激动剂 残 留量[J]. 质 谱 学报,2 0 0 5 , 26(3): 1 29- 137. ) ( [ 7 ] 金 伟 ,黄 斌,王彬 .气 相色谱 /质谱法测 定水和沉积物中 雄 激 素 与孕 激 素[ J] . 分 析化学,20 1 3,41(2) : 205-2 0 9. ) ( [ 8 ] 王 培 龙,范理 , 苏晓鸥 . 分子印迹固相萃取 - 气相色谱 - 质 谱法测 定 猪 尿中4种β-受 体 激动剂 [J]. 分 析 化学,2 0 12, 4 0 (3) : 4 70-473. ) ( 收稿日期:2016- 0 4- 2 8 ) 网址: www. yuweichina.com 邮箱watercom 目的 本实验利用薄层净化与气质联用仪相结合技术,建立了快速检测动物组织中残留瘦肉精的方法。方法通过优化薄层展开程序,获得瘦肉精在自制的纸基薄层板上稳定的比移值(Rf)。样品经过提取、浓缩后,在纸基薄层板上进行净化,通过裁切目标区,以甲醇洗脱,洗脱液经衍生剂反应后,用气质联用仪,在SIM模式下检测定量。结果在优化条件方法下,样品中的杂质得到完全分离。在浓度范围为0.02μg/ml~0.5μg/ml时,线性关系良好,线性回归方程为y=358 971x+18 441,r=0.999 2;加标回收率为71.3%~84.7%(外标法),最低检出限为2.0μg/kg(基于3倍信噪比)。结论 本方法操作快速方便、灵敏准确,能满足猪肉样品中瘦肉精的快速分析要求。不仅节约了前处理时间,更有效地降低了溶剂消耗,表现出环境友好等特点。纸基薄层色谱条带有望在农产品样品前处理领域获得良好应用。
关闭还剩2页未读,是否继续阅读?
北京豫维科技有限公司为您提供《猪肉中瘦肉精的残留检测方案(毛细管柱)》,该方案主要用于畜禽肉及副产品中兽药残留检测,参考标准《GB/T 21981动物源食品中激素多残留检测方法 液相色谱-质谱/质谱法》,《猪肉中瘦肉精的残留检测方案(毛细管柱)》用到的仪器有null。
