电源技术Chinese J ournal of Power Souroes研 究 与 设 计 铝在碱性电解液中的阳极行为 余祖孝 ,陈昌国,罗忠礼?,李 荣 (1.四川理工学院材料与化学工程系,四川自贡643033;2.重庆大学化学化工学院,重庆400044;3.重庆师范大学化学学院,重庆400047) 摘要:用电化学方法研究了Al(99.999%~99.5%)在4 mol/L KOH溶液中的阳极行为,结果表明:杂质(Fe,Si,Cu)含量递增,铝的传递电阻变小、腐蚀速度增大,达到稳定开路电位所需时间延长,但50℃时商业铝A1 99.82%的极化程度最小,在-1.224V下有 400 mA/cm²大电流产生;温度升高而铝阳极的活化作用随之增强,但腐蚀也加剧;铝电极在5mmol/L NazSnO+4 mol/L KOH 中的浸泡时间为20 min 较适合;添加剂NazSnOs对铝的腐蚀抑制、电学学性能改善都者生有利影响,其最佳最度为5 mmol/L。 关键词:铝阳极;氢氧化钾;添加剂;电化学性能 中图分类号:TM911.41 文献标识码:A 文章编号:1002-087 X(2005) 09-0602-05 Electrochemical behaviour of aluminum in alkaline solution YU Zu-xiao', CHEN Chang-guo?, LUO Zhong-li, Li Rong' (1.Dept. of Material and Chemical Engineering, Sichuan University of Science and Engineering, Zigong Sichuan 643033,China;2. College of Chemistry and Chemical Engineering, Chongqing University Chongqing 400044, China;3. College of Chemistry, Chongqing Normal University,Chongqing 400044,China) Abstract: Anodic behaviours of Al (99.999%~99.5%) have been studied by using electrochemical technique in 4 mol/LKOH solution. The results indicade that Al has high activation performance and high corrossion when temperature rises;When content of impurities (Fe,Si,Cu) increases, Al has high corrossion and achieving stable open circuit potential needslonger time; however ,Al 99.82% has slower polarization and higher current (400 mA/cm²) than others at 50 ℃; In order toachieve stable Eop and avoid appearance of Sn apices, 20 min is suitable for Al dipping in 5 mmol/L Na,SnO; +4 mol/L KOH;good electrochemical behaviour of Al including corrosion-resistance and activation performanc has been achieved by addingadditive of Na,SnO, into 4 mol/L KOH, and 5mmol/L is the most suitable concentration of Na,SnOs。 Key words: aluminum anode,KOH,additive,electrochemical properties 铝-空气电池中的空气电极、电池的结构等研究目前已经取得较大进展.2。其中的铝阳极是一种高强度能量载体,电化学当量高(2.98Ah/g),电位负(-2.35V vs.SHE), 能提供大的功率,如铝-空气电池理论能量密度可达8100 Wh/kg,为铅酸电池的47.5倍,且对环境非常友好的优秀电池,所以铝是开发电池的理想电电材料3~61。但铝的极化和腐蚀相当严重,使铝-空气电池未能发挥高能源的优势,虽然目前采用添加剂能够活化铝阳极和抑制腐蚀,但铝在电解液中有胶状产物Al(OH)产生不不易分离,因此,铝-空气电池中的铝阳极及电解液具有非常重要的地位和作用,本文研究了四种纯铝材料在4 mol/L KOH溶液中的阳极行为以及添加剂NazSnO,对它们的影响。 1实验 1.1铝材料、电极、试剂准备及仪器 纯铝材料:高纯铝(纯度99.999%,抚顺铝厂),简称 ( 收稿日期:2004-11-17 ) ( 作者简介:余祖孝(1964一), 男 ,重庆市人,硕士,讲师,主要研究方向为电化学。 ) A1-1;纯铝(纯度99.99%),简称Al-2;商业铝(99.82%,天津市大茂化学仪器供应站),简称Al-3;工业铝(99.5%),简称 A1-4。它们的主要杂质 Fe、Si、Cu 的含量依次递增,见表1.电极:(1)研究电极:铝。将上述四种铝材料的一端表面裸露,其余用环氧树酯密封,分别用1200*、2000*、3000*金相砂纸打磨,然后用蒸馏水洗、乙醇除油,再用蒸馏水冲洗晾干用于待测。(2)辅助电极:石墨。(3)参比电极:HgO/Hg,OH(4mol/L)。 试剂:KOH分析纯),NazSnO(分析纯),二次蒸馏水。 仪器:用天津兰力科化学电子高技术有限公司生产的LK98BⅡ微机电学学分析系统,测量铝阳极的线性扫描伏安曲线(1mV/s)、塔菲尔曲线(1mV/s)以及开路电位随时间变化曲线;用 CHI660a 电化学工作站(美国)测量铝阳极的交流阻抗图谱。 Fe Si Cu A1-1 0.00030 0.00030 0.00036 A1-2 0.00070 0.00075 0.0D2 00 A1-3 0.015 0.15 0.015 Al-4 0.30 0.30 0.015 此外,除特殊说明外,温度均为室温;规定氧化电流密度为负值。 1.2缓蚀率 式中:JcomR为无添加剂时铝的腐蚀电流密度和电荷传递电阻;J'comR'为有添加剂时铝的腐蚀电流密度和电荷传递电阻。 2结果与讨论 2.1铝阳极行为的影响因素 2.1.1杂质(Fe,Cu,Si) (11)腐蚀速度Jcom:铝电极的特殊要求之一是不允许有寄生析氢腐蚀发生,否则会产生不输出能量的自溶解(阳极利用率降低)和大量析氢(加大电池系统负担)。表2和表3的数据表明:随杂质含量递增(见表1),腐蚀电流密度增加(特别是Al-3在50℃下腐蚀速度急剧增加);从交流阻抗图1和表4也得出相同的的论:随杂质含量的增加,传递电阻 R.值减小,则析氢腐蚀速度增大。因此杂质含量的增多,铝阳极没有积极参与放电,而去产生寄生析氢腐蚀,其原因8-11]:①杂质相的电极电位较高,纯铝中存在电化学活性较差的Si (-0.445 V)、Fe(-0.441 V)、Cu(0.36V)等微量杂质或与铝形成电化学活性活的微阴极相化合物 FeAl; (-0.56V)、Al,Cu(- 0.54V)、Al,Fe Si,(-0.58V),这些杂质以微阴极相形式(在晶界处)与铝基体阳极(-1.67V)形成短路的腐蚀微电池,造成铝电位正移,加速铝的析氢腐蚀;②氢离子在阴极杂质相上的氢过电位不大(例如杂质Fe 的氢过电位在10mA/cm²时为0.53V,100 mA/cm²时为0.64V),故阴极相FeAl; 等很容易得到电子而还原析氢;③微观组织分析,表明A1-2中存在的微量杂质以第二相形式不均匀地分布在铝的晶界处,且第二相的晶粒粗大,造成铝基体内部的点缺陷,破坏钝化膜,加速铝腐蚀,此外我们还观察到A1-2在碱液浸泡后其表面仍然光亮,但整个电极表面腐蚀极不均匀。(2)极化程度:随杂质含量增加而极化程度降低除Al-4外),表明两种高纯铝的钝化相当严重(钝化膜造成),但是商业铝(Al-3)的极化程度最小,50℃时居然在-1.224V下有400mA/cm²大电流产生,且商业铝的成本低(但腐蚀速度也大)。因此只要能控制杂质 Fe、Si、cu含量,它应该成为铝阳极研究的重点。(3)开路电位Vocp:随杂质含量递增,铝的开路电位正移,达到稳定开路电位Vs所需时间也延长,并且随温度升高而达到V所需时间缩短。 表24种铝材的电化学性能(4 mol/L KOH25℃) Tab.2Electrochemical properties of four kinds of aluminiums in 4 mol/L KOH at 25℃ Joor [mA.cm VeomV Vop VIV VV i/s 25 mA/cm* 50 mA/cm Al-1 15.52 -1.708 -1.700 -1.738 214 -1.426 0.2820 -L.241 0.467 A1-2 20.12 1.691 -1.668 -1.686 228 -1.456 0.2350 -1.232 0.459 Al-3 30.27 -1.507 -1502 -1.407 336 -1.400 0.0979 -1.287 0.220 A1-4 30.29 -1.460 -1429 -1.380 637 -1.354 0.1010 -1.191 0.225 注:V表示开始时的开路电位.Va表示达稳定时的开路电位,t表示达到稳定时所需时间 表34种铝材的电化学性能 (4 mol/L KOH 50℃) Tab.3 Electrochemical properties of four kinds of aluminiums in 4 mol/L KOH at 50℃ (mA.cm) Veor’ Vecpt VV和V VJV VV t/s 100 mA/cm 200mA/cm 400 mA/cm" A1-1 75.32 1.77 -1.733 -1.800 10 -1.455 0.344 -1.255 0.544 A1-2 62.00 -1.782 -1.763 1.750 20 -1.418 0.364 -1.165 0.617 A1-3 267.62 -1.417 一-1.514 -1.530 204 1.374 0.043 -1327 0.090 1.224 0.193 AI-4 270.00 -1.398 -1.405 1.384 260 -1.2450.093 图1 4种纯铝的交流阻抗图谱 4mol/L KOH, Vo) Fig.1 EIS of Al-1,Al-2,Al-3 and Al-4 in 4mol/L KOH at Vop Tab.4 Parameters obtained from EISoffour kinds of aluminums 类型 Al-1 Al-2 A1-3 A1-4 RQ·cm3 3.08 2.80 1.75 1.20 总之,杂质对铝阳极的电化学行为产生不利影响,因此要严格控制其杂质含量。 2.1.2温度 随着电解液温度的升高,溶液的对流、扩散增加,电解液电阻降低,提高了氢氧化钾溶液的电导率,铝电极反应速度加快,铝钝化变得困难,氧化膜电阻极化降低,减弱了铝的阳极极化,促使其活化溶解(见图2),同时铝表面上的氧化膜在碱液中溶解度增加,也会使铝的电化学极化降低,因此温度每升高10℃,Al 的极化减少程度是成倍增长(见表5),开路电位也随温度升高而负移,但负移程度不大(见表5).但是阴极氢去极化作用增强,可能与杂质阴极相的电位随温度升高而改变有关,即氢过电位随温度升高而降低,析氢速度增大(见图3和表5),造成电流效率降低;另外,在高温下晶间腐蚀加剧,导致晶粒脱落也加剧,这是高温下阳极电流效率降低的另一个重要原因。因此研究铝-空气电池的温度为50℃或60℃,否则腐蚀加剧,此外在保证铝阳极电化学性能不受影响条件下,如何把温度降低到常温进行研究是很有意义的。 2.2添加剂NazSn03对铝阳极电化学行为的影响 2.2.1浸泡时间 图4为浸泡时间t对Al-2在5mmol/L NazSnO;+4 mol/LKOH中极化曲线的影响,表明浸泡时间t≤20 min,极化曲线几乎无变化,但是 t≥30 min 则会出现微弱的锡峰[因为易在碱性介质中的标准平衡电位为-1.013V vs.(Hg/HgO)]。我们 图2温度对Al-2极化曲线的影响 Fig.2 Polarization curves for Al-2 图3 温度对Al-2的 Tafel 曲线影响Fig.3Tafel curves for Al-2 用金属锡作该实验也表明在同一位置出现氧化峰,如果NazSnOs 浓度越大,出现的锡峰越明显[当C( NazSnO)≥50mmol/L 时,直接观察到灰黑色物质锡在铝表面上出现]。图5表明:反应开始时,Al-2的开路电位Vocp相当不稳定,急剧正 表5温度对AI-2阳极行为的影响(4 mol/L KOH) Tab.5 Effect of temperature on electrochemical properties of Al-2 in 4 mol/L KOH 温度/℃ Jeom/(mA.cm) 极化减少程少(mA/-1.7~-1.0V) 30 15.60 -1.65 8.940 40 22.53 -1.741 16.450 50 66.61 -1.763 29.550 60 92.64 -1.775 61.230 图4浸泡时间对Al-2极化的影响 Fig.4 Effect of dipping-time on polarization of Al-2 in 5 mmol/LNa,SnO+4 mol/L KOH 图5 浸泡时间对Al-2开路电位的影响 Fig.5 Effect of dipping-time on Vop of A1-2 in 5 mmol/LNa,SnO;+4 mol/L KOH 移;但Vop随Al-2的浸泡时间延长长趋于稳定(t≥20 minVop才达到稳定)。因此铝电极在5 mmol/L NazSnO; +4mol/L KOH 中的浸泡时间为20 min 较适合,如果浸泡时间太短,则铝的开路电位不稳定,如果浸泡时间太长,则会有锡峰出现。 22.2 腐蚀速度(Jcomr) SnO有抑制腐蚀作用:图6图NazSnO对4种铝电极材料 Jcorr 的影响(4mol/L KOH),结果表明:当C(NazSnO3)=0~5 mmol/L 时,其 Jcorr 逐渐变小但变化不大;当 C(NazSnO3)=5~10 mmol/L 时, 则 Jcor急剧增加;当C(NazSnO;)≥10 mmol/L 图66NaSnO付铝腐蚀速度的影响(4mol/LKOH) Fig.6)C(orrosion rates of aluminiums in x mmol/LNa,SnO+4mol/L KOH 时, Jcor又基本上不变,所以选择 C(NazSnOs)=5m mol/L较佳;图7是在开路电位处,有无 NazSnOs添加剂时Al-1的交流阻抗图谱,表明有添加剂时R.值变大,缓蚀率增加(见表6),但是NazSnOs浓度继续增大,缓蚀率反而降低,即存在一个最佳浓度值。因此,5 mmol/L NazSnO是一种有效抑制腐蚀的添加剂,这是因为 SnO?被还原成金属 Sn,锡在铝中的溶解度为 0.07%3,低锡时,锡溶解于铝中形成固熔体,不会增加铝的偏析相,还能消除杂质铁硅铜等的不利影响,细化枝晶组织,使铝组织更均匀,产生全面腐蚀,所以SnO?起到了一个良好的抑制析氢腐蚀作用;高锡时(!即锡含量超过固熔度时),在晶界处将出现更多的偏析相,锡相使晶界优先溶解,自腐蚀增加,腐蚀极不均匀。 图71在开路电位下,Al-1在不同电解液中的交流阻抗谱 Fig.7EIS of Al-1 in different alkaline solution at Voc, 表6来自于Al-1交流阻抗的腐蚀参数 Tab.6 Parameters obtained from EIS ofpure aluminum-1 22.3活化程度 NazSnO有活化作用:图8是NazSnO对 Al-1阳极极化曲线的影响(4mol/L KOH),其它3种铝的极化曲线与之相似,结果表明:(1)当C(NazSnO3)≤2 mmol/L 时,NazSnOs对铝阳极活化几乎无影响,可能锡的含量太少,在铝电极表面上还未形成活性铝-锡合金。(2)当 C(NazSnO)=5 mmol/L时,NazSnOs对铝阳极活化产生急剧提高(即曲线3的斜率急增),图9进一步表明,当C(NazSnO3)=5 mmol/L时(曲线4),其极限电流密度出现较迟,这是因为:第一,主要是降低氧化膜电阻,Sn+在氧化膜表面取代 Al并产生一个空穴,使氧化膜电阻明显降低(AlOs的电阻率率1010W·m降到7×107W·m)I14]; 第二,在实验过程中观察到烧杯底部有白色胶状物产生,因为添加剂 NazSnO( 水解)→胶态 Sn(OH)4,而 Sn(OH)4 作为 Al(OH)沉淀的晶核;第三,少量 Sn 在铝中 3. 5 mmol/L Na SnO,: 4. 10 mmol/L Na,SnO,:5. 15 mmol/L Na,SnO,: 6. 25 mmol/L Na,SnO, 图8NaSnO; 对 Al-1极化程度的影响Fig.83FPolarization curves for Al-1 1. 0 mmol/L Na,SnO,: 2. 1 mmol/LNa,SnO,: 3. 2 mmol/L Na,SnO,: 4. 5 mmol/L Na,SnO,:5. 10 mmol/L Na,SnO,: 6. 15 mmol/LNa,SnO,:7.25mmol/L Na,SnO, 图9 NazSnO,对 A1-1 的 Tafe 曲线影响Fig.9Tafel curves of Al-1 形成固熔体,破坏钝化膜,使铝均匀腐蚀,以上三因素使铝阳极活化。(3)当 C(NazSnO;)≥10 mmol/L 时,活化提高程度减缓;当C(NazSnO三)=15 mmol/L时,活化程度达到最大值(即极化曲线的斜率最大);当C(NazSnO3)=25 mmol/L时,活化程度又开始下降,原因是随着大量疏松的锡沉积在铝表面上,锡易脱落而铝会加速析氢腐蚀,因此铝的活化作用降低。综上所述,虽然C(NazSnOs)=15 mmol/L时对4种铝阳极的活化达到最大值,但是该浓度下的 Jcon也较大,以及 Vocp 不再负移,还可能会影响电解液的电导率,因此 C(NazSnO3)=5 mmol/L是最佳浓度值。 2.24开路电位(Vcp) 添加剂NazSnO; 对四种铝电极材料开路电位Vo,的影响(4 mol/L KOH、30℃)见图10,结果表明:Vocp随NazSnO浓度增加而不断负移(即活性提高,除Al-3外),直到C(NazSnO3)=5 mmol/L 为止,当C(NazSnO3)>5 mmol/L 时, Vocp基本上保持不变;图9是 Al-1 的 Tafel 曲线,也表明了上述相同结论。因此当C(NazSnO3)=5 mmol/L 时, Vocp负移达到最佳值,开路电位正移或负移与钝化膜的增减有关,少少锡(<0.07%)熔于铝中形成固熔体,对铝的晶粒有细化作用,破坏铝的钝化膜,使开路电位负移。 图10NazSnO对4种铝Vocp的影响 Fig.10Effects ofNazSnO;on Vo of four kinds of aluminiumsin 4 mol/L KOH 22.5放电性能 随电流密度的度增, Al-1在 4 mol/L KOH 溶液中的电极电位滞后时间迅迅由26s上升到158s(见表7),意味着铝钝化膜增厚,可是添加5 mmol/L NazSnOs时,则Al-1电极电位滞后时间变短,不随电流密度的递增而增加,基本上保持不变,即 NazSnO;参与了破坏铝钝化膜的作用,使铝电极电位快速达到稳定。表8表明: Al-1在 4 mol/L KOH 溶液中的电极电位随电流密度递增而快速递减,递是添加 5 mmol/LNazSnO贝时,电铝电极电位产生负移,且随电流密度递增,电 表7AI-1的电位滞后时间 Tab.7 Potential hysteresis of Al-1 atdifferent solution and current density 电位滑后时/S 80 mA.cm-2 100 mAcm工 120 mA.cm-2 4molL KOH 26 78 258 4 mol/L KOH+5mmol/LNaaSnOs 23 31 26 电位滞后时间降低值 3 39 132 图4实验波形 Fig.4Experimental waveforms (上接第606页) 表8Al-1的电极电位 Tab.8 Potential of Al-1 at different solution and current density(vs.Hg/HgO) 电极电位/V(ys.H/HgO) 80 mAcm 100 mAcm 120mA-cm 4 mol/L KOH 一1.091 3 -0.7466 -D.4333 4molLKOH+ 5mmol/L NaaSnOs -1.1478 -0.9848 -0.8092 电极电位负移 0.0565 0.2382 0.3759 极电位负移程度增大,说明添加剂NazSnOs在高电流密度下也能破坏钝化膜。 3:结论 Al-1、A1-2、A1-3、A1-4在4mol/L KOH 及添加剂 NazSnOs溶液中的电化学行为表明:(1)杂质(Fe,Si,Cu)含量越高,铝在碱液中的腐蚀越严重,达到稳定开路电位所需时间越长。但50℃时商业Al-3(99.82%)的极化程度最小,在-1.224V下有 400 mA/cm²大电流产生,且商业铝的成本低(但腐蚀速度也大),因此只要能够控制杂质的影响,它应该成为铝阳极研究的重点。(2)温度升高而铝阳极的活化作用随之增强,但是腐蚀也加剧。(3)铝电极在4 mol/L KOH +5 mmol/L NazSnO溶液中的浸泡时间为20 min 较适合。(4)NazSnO;对铝的腐蚀抑制、电化学性能改善都产生有利影响,其最佳浓度为5mmol/L。 ( 参考文献: ) ( [1] L I Q F, BIERRUM N J . Aluminum as anode for energy storage and c onversion: a review[J]. J Power Sources, 2002, 110:1一10. ) ( 2] SHEN P K,TSEUNG A C C. De s ign of a dome-shaped aluminium ) 输入电压/V 90 120 220 260 空载/W 0.38 0.34 0.32 0.33 满载效率(%) 84.40 84,60 83.40 82.80 输出纹波/mV 70 65 45 40 提出了开关频率优化配置的PWM控制方案。在轻载的时候同时减小占空比和降低开关频率,使得电路始终工作在优化的频率下。实验结果证明上述设计方法和控制方案的实用性和可行性。该充电器的设计思路可以应用于手机、笔记本电脑等领域的电池充电设备中。 ( 参考文献: ) ( [1 ] 引 张占松,蔡宣三.开关电源的原理和设计[M].北京:电子工业出 版社,1998.237一259. ) ( [2] 陈坚.电力电子学[M].北京:高等教育出版社,2002.18. ) ( [3] 苗海亮,武慧,雷准刚,等.变频空调用新型高性能开关电源的设 计[J].电力电子技术,2004,38( 1 ):81一83. ) ( [4] 胡从中. DC-DC 电源系统的优化设计[J].电子技术应用,2001 ( 12):34一35. ) ( water battery [J ] . J Ap p l Electrochem . 1994,24 : 14 5 —148. ) ( [3] EQUEY L F, MULLER S,DESILVESTRO J,et al . E l ectrochemicalproperties of aluminium i n w e akly ac i dic so d iumchloride solutions.I.Influence of the electrolyt e additives H g ,In,Ga and S n²[ J ]. J Electrochem Soc , 1992 , 139 (6 ) : 1499- 1 502. ) ( [4] 房振乾,刘文西,陈玉如铝-空气燃料电池的研究进展[].兵器 材料科学与工程,2 0 03,26(2):67-72. ) ( [5] 桂长清.铝空气电池的前景[J].电池,2002,32(5):305—307. ) ( SHAO H B , WANG JM,W A NG X Y, e t al. A no d ic dissolution ofaluminum in K O H ethanol solution [J]. E lectrochemistry C ommuni- cations,2004,6:6—9. ) ( [7] SHAO H B , W ANG J M, Z HANG Z, et al . The cooperative e f fect of calcium i o ns a n d tartrate ions on t h e c o rrosion[J]. Materials Chemis-try and Physics,2002,77:305309. ) ( [8] JOHN A M , ANIBU K, GANESAN M, et al. C h ar a cterisation ofdifferent grades of commercially pure aluminium as prospective gal-vanic a nodes i n s a line a n d alkaline ba t tery electrolyte [ ] . J A p p l Electrochem,1989,19:547—551. ) ( [9] 游文,林顺岩.杂质对 Al-Ga-Bi-Bb 合金电化性能的影响[J].铝加 工,1998,21(5) : 35—38. ) ( [10] 马正青,黎文献,王日初,等.铝合金阳极在碱性介质中的电化学 性能[J].电源技术,2002,26(5):365—368. ) ( [11] 马正青,黎文献,肖丁德,等.新型铝合金电化学性能与组织研究 [J].材料保护,2002,35(5):10一12. ) ( [12] 屈钧破,齐公台.铝阳极电流效率的影响因素[J].中国海上油气, 2001,13 ( 5 ) :11-1 3 . ) ( [131 齐公台,郭稚弧,魏伯康.不同锡含量高温铝基牺牲阳极的电化 学性能[J].材料保护,1999,32(10):29—30. ) ( [14] 蔡年生.电池用铝合金的开发应用[].铝加工,1996,19(4): 44—46. ) Vol.No.Sep.
关闭还剩4页未读,是否继续阅读?
天津市兰力科化学电子高技术有限公司为您提供《碱性电解液中铝的阳极行为检测方案(电化学工作站)》,该方案主要用于其他中电化学性能检测,参考标准《暂无》,《碱性电解液中铝的阳极行为检测方案(电化学工作站)》用到的仪器有天津兰力科电化学工作站LK98BII。
