Vol 23 No. 3Jun 2007广 东 药 学 院 学 报JOURNAL OF GUANGDONG COLLEGE OF PHARMACY第23卷第3期2007年6月 广东药学院学报,2007,23(3) 中药与天然药物】 毛细管电泳法测定银黄胶囊及银黄颗粒中黄芩苷和绿原酸的含量 宋粉云,龚红全,林 琳 ,彭子彦*(广东药学院药物分析教研室,广东广州510006) 摘要:目的建立同时测定银黄胶囊及银黄颗粒中黄芩苷和绿原酸含量的方法。方法采用毛细管电泳法,电泳条件:未涂层弹性融硅石英毛细管柱(55 cm X75 um D,有效长度47 cm);以 40 mmol/L硼砂溶液(pH9.30)为运行缓冲液;分离电压15kV;重力进样5s(高度15cm);检测波长310 mm。结果以对硝基苯甲酸为内标,黄芩苷、绿原酸的线性范围分别为20.2~101. 0ug/mL(r=0.9981),5.15~25. 75 pg/mL (r=0.9991)。银黄胶囊中黄芩苷、绿原酸的平均回收率分别为105.0%、97.2%,银黄颗粒中黄芩芩、绿原酸的平均回收率分别为101.3%、96.6%。结论该法简便、快速、准确可靠,可用于银黄胶囊及银黄颗粒的质量控制。 关键词:毛细管电泳;银黄胶囊;银黄颗粒;黄芩苷;绿原酸 中图分类号:R284.2文献标识码:A 文章编号:1006-8783(2007)03-0231-03 Determ ination of baicalin and chlorogen ic acidinYinhuang capsules and Yinhuang granules bycapillary electrophoresis SONG Fen-yun, GONG Hong-quan, L N Lin’,PENG Zi-yan (Guangdong College of Pham acy, Guangzhou, Guangdong 510006, China) Abstract:Objective To establish a method for the content detem ination of baicalin and chlorogenic acid in Yinhuang cap sules andYinhuang granules M ethods Samples were analyzed on a uncoated fused silica cap illary (55 cm X75 um, 47 cm) using 40 mmol/LNaBO, (pH 9. 30) as running bufferTThe voltage was 15 kV.l.The detection wavelength was 310 nm.n.Results The method wasvalidated over linear ranges of20. 2~101 ug/mL (r=0. 9981) for baicalin and 5. 15~25.75ug/mL(r=0. 9991) for chlorogenic acidThe average recoveries of baicalin and chlorogenic acid in Yinhuang cap sules were 105. 0% and 97. 2%, respectively The averagerecoveries of baicalin and chlorogenic acid in Yinhuang granules were 101. 3% and 96. 6%, respectively Conclusion This techniqueprovides a sensitive, rap id, rep roducible and inexpensive assay suitable for quantitative detem ination of baicalin and chlorogenic acid inYinhuang cap sules and Yinhuang granules Key words: cap illary electrop horesis; Yinhuang cap sules; Yinhuang granules; baicalin;chlorogenic acid 银黄胶囊与银黄颗粒是由金银花提取物与黄芩提取物制成的中药成方制剂,具有清热、解毒之功效。临床用于治疗急慢性扁桃体炎,急慢性咽喉炎,上呼吸道感染。产品现行标准标1.21只收载了黄芩普的 HPLC法含量测定,文献[3-8]报道采用 HPLC法测定银黄胶囊或银黄颗粒中黄芩芩苷绿原酸含量,但高效毛细管电泳法(HPCE)对银黄胶囊及银黄粒的质量控制研究未见文献报道。本文结果表明,HPCE法具有分离效果好、快速、简便等优点,可用于银黄制剂的质量控制。 ( 广东药学院公公卫生学院卫生检验专业2003级学生 ) ( 基金项目:广东省自然科学基金资助项目(5002841) ) ( 作者简介:宋粉云(1965-),女,副教授,硕士,从事药物分析 的教学和科研工作,电话:13660528126, Email:fuhaiwu@163. net. ) 仪器与试药 CL1030型高效毛细管电泳仪(北京彩陆科学仪器有限公司),德国 KNAUER K-2501紫外可见检测器,HW-2000色谱工作站2.17版(南京千谱软件有限公司)。ORDNMODEL 828型pH计(美国)。DL-360超声波清洗器(宁波石浦海天电子仪器厂),工作频率(4.5±0.05)kHz,输出功率240W。未涂层弹性融硅石英毛细管柱(75um D,总长55 cm,有效长度47 cm,河北锐年永色色谱器件有限公司)。 黄芩苷对照品(中国药品生物制品检定所,批号:110715-200514);绿原酸对照品(中国药品生物制品检定所,批号:110753-200413);银黄胶囊(中山市中智制药有限公司,每粒0.3g);银黄颗粒(中山市中智制药有限公司,每包4g);硼砂、对硝基苯甲 酸、NaOH、甲醇等均为分析纯,水为二次蒸馏水。 2 实验部分 2.1 溶液的制备 2.1.11内标溶液 精密称取对硝基苯甲酸一定量,加甲醇制成300 pg/mL的内标贮备液。 2.1.2 对照品溶液 精密称取黄芩苷对照品 20.2 mg,置 100mL量瓶中,加75%(体积分数)甲醇溶解并稀释至刻度,摇匀,作为对照品贮备液(质量浓度为202ug/mL);精密称取绿原酸对照品10.3mg置100mL量瓶中,加50%(体积分数)甲醇溶解并稀释至刻度,摇匀,作为对照品贮备液(质量浓度为103ug/mL)。 2.1.3 供试品溶液的制备 银黄胶囊:取本品20粒,精密称定重量,倾出内容物,将囊壳拭净,精密称定囊壳重量,求得平均装量。取混匀的内容物约0.5 g,精密称定,置具塞锥型瓶中,精密加入50%(体积分数)甲醇50 mL,称定重量,超声处理30min,放冷,称重,用50%(体积分数)甲醇补足减失的重量,摇匀,滤过,弃去初滤液,精密量取续滤液2mL,置25mL量瓶中,精密加入内标贮备液5mL,加 50%(体积分数)的甲醇稀释至刻度,摇匀,0.45um滤膜过滤,取续滤液,即得。 银黄颗粒:取银黄颗粒,研碎,取约1g,精密称定,置具塞锥型瓶中,精密加入50%(体积分数)甲醇 50mL,称定重量,超声处理30min,放冷,称重,用50%(体积分数)甲醇补足减失的重量,摇匀,滤过,弃去初滤液,精密量取续滤液2mL,置25 mL量瓶中,精密加入内标贮备液5mL,加 50%(体积分数)的甲醇稀释至刻度,摇匀,0.45 um滤膜过滤,取续滤液,即得。 2.2 电泳条件 未涂层弹性融硅石英毛细管柱(55 cm ×75 umD),有效长度47 cm;以 40 mmol/L 硼砂溶液 (pH9.30)为运行缓冲液;分离电压15 kV;重力进样5 s(高度15cm);检测波长310mm;温度25℃,湿度小于70%。毛细管柱在使用前依次用00.11mol/LNaOH溶液、水、运行缓冲液各冲洗约5min,样品分析间隔用运行缓冲液平衡2min。在此条件下,对照品、样品色谱图如图1所示。 2.3 标准曲线制备 分别吸取一定量的黄芩苷、绿原酸、对硝基苯甲 酸对照品贮备液,加50%(体积分数)甲醇稀释成含黄芩苷质量浓度为220.2、40.4、60.6、80.8、101.0ug/mL,绿原酸质量浓度为5.15、10.3、15.45、20.6、25. 75 ug/mL与内标溶液质量浓度为 60ug/mL的溶液。依次重力进样5 s,每个浓度测定3次以上。以对照品与内标峰面积的比值(A)为纵坐标,对照品溶液浓度()为横坐标进行线性回归,分别得回归方程: 表明黄芩苷质量浓度在20.2~101.0pg/mL、绿原酸质量浓度在5.15~25.75 pg/mL与峰面积的线性关系良好。 1.黄芩苷;2绿原酸;3.内标物 A.对照品;B.银黄胶囊;C银黄颗粒 图1 对照品、样品的毛细管电泳色谱图 Fig 1 Chromatogram s of standard and sam ple 2.4 精密度试验 取质量浓度分别为60.6、15.45 ug/mL的黄芩苷与绿原酸对照品溶液,重力进样5s,连续测5次,记录峰面积并计算RSD。结果:黄芩苷的 RSD=1.42%,绿原酸的 RSD=1.56%,表明仪器精密度良好。 2.5 稳定性试验 取供试品溶液在 0、2、4、6、8、10、12 h,分别重力进样.55 s,记录峰面积。结果:银黄胶囊(批号:20050906)黄芩苷的 RSD=1.98%,绿原酸的 RSD=2.73%,表明供试品溶液在12h内稳定;银黄颗粒(批号:20060918)黄芩苷的 RSD=1. 75%,绿原酸的RSD=3.03%,表明供试品溶液在8h内稳定。 2.6 重复性试验 分别取银黄胶囊(批号:20050906)或银黄颗粒(批号:20060918)样品6份,按“2.1.3"项下方法提 取、测定。结果:银黄胶囊黄芩苷的平均含量为61.82mg/g,RSD=1. 60%(n=6),绿原酸的平均含量为11.82mg/g,RSD=2. 24%(n=6);银黄颗粒黄芩苷的平均含量为32.04mg/g,RSD=239%(n=6),绿原酸的平均含量为5.72 mg/g, RSD =219%(n=6)。表明分析方法精密度良好。 2.7 加样回收试验 精密称取银黄胶囊(批号:20050906)或银黄颗粒(批号:20060918)样品各6份,加入相应量的黄芩苷或绿原酸对照品,按“2.1.3"项下方法处理并测定,计算回收率,结果:银黄胶囊黄芩苷及绿原酸的平均回收率分别为105. 0% (RSD=242%),97.2%(RSD=1. 45%);银黄颗粒黄芩及绿原酸的平均回收率分别为101.3%(RSD=1. 73%),966%(RSD =285%)。结果表明方法准确、可靠。 2.8 样品测定 取银黄胶囊或银黄颗粒样品各3批,按“21.3”项下方法处理后测定,记录峰面积,代入回归方程计算样品中黄芩苷与绿原酸的含量,结果见表1. 表1样品测定结果 Tab1 Results of sam ple detection (n=3) 黄芩苷 绿原酸 样品 批号 w/ RSD/ w/ RSD/ (mg·粒 ) % (mg·粒 % 银黄 20050905 22.93 245 4.10 2.05 胶囊 20050906 18.82 1.60 3.60 2.25 20050907 22.63 2.46 2.62 1.77 银黄 20060918 3204 239 5.72 219 颗粒 20060919 30.08 1.26 5.60 1.83 20061004 30.64 2.02 5.26 0.86 3 讨论 3.1 检测波长的选择 实验发现黄芩普在278mm处有最大吸收,绿原酸在315mm处有最大吸收,考虑到样品中绿原酸的量大大低于黄芩苷,故参照文献「9]选择310mm作为检测波长。 3.2 内标物的选择 为克服毛细管电泳重现性差的缺点,本文采用内标法定量。曾选用在310nm处有吸收的苯甲酸钠、对氨基苯甲酸、对硝基苯甲酸为内标物,结果:苯甲酸钠在体系中不出峰;对氨基苯甲酸峰灵敏度低、且保留时间长;对硝基苯甲酸峰型好,出峰时间与黄芩苷、绿原酸接近,在样品中无干扰,故选做内标物。 3.3 电泳条件的选择 银黄制剂中黄芩、绿原酸的含量测定,主要采 用毛细管区带电泳,采用硼砂溶液为缓冲液[9.101,因为黄芩苷、绿原酸极性较强,容易离子化,在硼砂溶液中,黄芩苷中邻二羟基基团更易形成络离子【],加大离子化。本文亦选择硼砂溶液为运行缓冲液。 分别在 pH7.0~10.0、10~50 mmol/L缓冲液浓度范围和9~24 kV工作电压范围内研究了缓冲溶液 pH和浓度以及工作电压对分离的影响。在所研究的 pH7.0~9.5范围内随 pH增加,3种物质迁移时间整体上增加,分离度都符合要求;当 pH≥9.5时黄芩苷峰型不好或不出峰,考虑分析时间和分离度两方面影响,选择 pH9. 30作为最佳运行缓冲液。当硼砂溶液浓度小于30 mmol/L时,绿原酸和内标对硝基苯甲酸分不开;当硼砂溶液浓度大于50mmol/L时,电流太大,焦耳热严重,且各物质保留时间太长,因此选择40mmol/L作为最佳缓冲溶液浓度。随工作电压的提高,分离度下降,根据电压与电流的线性关系,最佳电压为18kV,综合灵敏度、分离度和焦耳热,选择15 kV作为最佳工作电压。 ( 参考文献: ) ( [1]YBZ13372004国家食品药品监督管理局标准(试行)S]. ) ( [2] YBZ04942005. 国家食品药品监督管理局标准(试行) [S]. ) ( [3]潘馨.高效液相法测定银黄胶囊中绿原酸及黄芩苷的含 量[J].中国现代应用药学杂志,2003,20(6):493-495. ) ( [4]刘永利,李冬梅,冯丽,等.RP-HPLC同时测定银黄胶囊 中绿原酸与黄芩苷含量[J].中成药,2006,28(8):1142 - 1 144. ) ( [5]郑玉光,邓国兴,刘翠艳,等.高效液相色谱法测定银黄胶囊中黄芩苷和绿原酸的含量[J].时珍国医国药, 2006,17(7):1195-1 1 96. ) ( [6]王收箐,王宏,李冠忠.HPLC及极管陈列检测器测定银 黄胶囊中绿原酸、黄芩苷的含量[J].山东医药工业, 2003,22(2): 1 4-15. ) ( [7]宣铁锋.银黄颗粒质量标准研究[J].中国药业,2006,15 (5):51- 5 2 ) ( [8]李宇清,刘劲松.HPLC测定银黄颗粒剂中绿原酸和黄 芩苷含量[J].现代中药研究与实践,2004,18(5):45-47. ) ( [9]杨新,韩凤梅,程智勇,等.银黄冲剂中黄芩苷和绿原酸 的毛细管电泳分离分析[J].色谱,1999,17(6):573-575. ) ( [10]吕元琦,邬春华,袁倬斌.毛细管电泳法测定清开灵口服液和银黄片中的的芩苷和绿原酸[J].理化检验:化 学分册,2006,42(5):337-3 3 8. ) ( [11]陈义.毛细管电泳技术及应用[M].北京:化学工业出 版社,2000:173-1 7 4. ) ( (收稿日期:2007-04-26) ) China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net
关闭还剩1页未读,是否继续阅读?
北京华阳利民仪器有限公司为您提供《银黄胶囊及银黄颗粒中黄芩苷和绿原酸的含量检测方案(毛细管电泳仪)》,该方案主要用于中药制剂中含量测定检测,参考标准《暂无》,《银黄胶囊及银黄颗粒中黄芩苷和绿原酸的含量检测方案(毛细管电泳仪)》用到的仪器有高效毛细管电泳仪(紫外检测)CL1030。
